宜鼎国际EDC 4000 Horizontal
产品分类:工控机 工控元器件 存储器 工控机配件 存储产品 FLASH
品牌:宜鼎国际
Features
Support static wear leveling algorithm
S.M.A.R.T. & i-S.M.A.R.T. Supported
Intelligent system for error recovery
High reliability & compatibility
Mechanical design for anti-vibration
Enhanced power cycling
Overview
Innodisk’s horizontal EDC 4000 fits into any platform with an IDE connector and provides a simple, fast path upgrade. Designed for industrial embedded applications that require a speedy booting process, the EDC 4000 upgrades the working environment efficiently and enhances data transfer rates with read and write performances of up to 40MB and 20MB per second respectively. The horizontal EDC 4000 comes in capacities ranging from 128MB to 8GB and is available in 40-pin and 44-pin horizontal connector packages.
The Innodisk horizontal EDC 4000 offers manufacturers a high-capacity solid-state flash memory solution that electrically complies with Personal Computer Memory Card International Association (PCMCIA) ATA standards.
Compatible with the IDE standard interface and ATA Standard
Supports PIO (0-4), Multiword DMA (0-2), and Ultra DMA (0-4) transfer modes
True IDE access mode
Extremely lightweight and reliable, with a low-profile form factor
Specifications
宜鼎国际首创InnoEx虚拟I/O扩充模块 实现敏捷部署 推动AI应用高效落地
宜鼎InnoOSR一鍵還原固態硬盘
宜鼎国际DDR5 WT ECC UDIMM工业用闪存模块
宜鼎国际DDR5 WT ECC SODIMM工业用闪存模块
宜鼎国际DDR5 WT RDIMM工业用闪存模块
