宜鼎国际CFast 3SE嵌入式储存卡
宜鼎国际CFast 3SE
产品分类:工控机 工控元器件 嵌入式系统 存储器 其它 工控机配件 存储产品 FLASH 存储产品
品牌:宜鼎国际
產品特色:
SATA III interface
Extremely low power consumption
iSMART disk health monitoring
Intelligent error recovery system
Excellent data transfer speed
Hardware write protect
Enhanced power cycling management
產品介紹:
The Innodisk CFast 3SE operates at SATA III 6.0 Gb/s, which offers data transfer rate of read up to 470MB/sec. and of sequential writeup to 250MB/s. Compliant with CFast 2.0 standard, it is designed with 7+17 pin connector and is SATA compatible. Due to the idle power saving, it reduces 30% power consumption. CFast 3SE is featured assmall form factor, and suitable for most industrial application.
CFast 3SE can work under harsh environment, and complies with ATA protocol. Without additional drives, the disk can be configured as a boot device or data storage device. CFast 3SE support hardware write protect to prevent modification of valuable data on a device. Besides, through Innodisk's enhanced power cycling technology and more capacitors, CFast 3SE prevents data loss caused by sudden power failure. By using Innodsik's iSMART, users can not only monitor the operation status of SSD, but also visualize Wear-Leveling status with graphics.
規格:
宜鼎国际首创InnoEx虚拟I/O扩充模块 实现敏捷部署 推动AI应用高效落地
宜鼎InnoOSR一鍵還原固態硬盘
宜鼎国际DDR5 WT ECC UDIMM工业用闪存模块
宜鼎国际DDR5 WT ECC SODIMM工业用闪存模块
宜鼎国际DDR5 WT RDIMM工业用闪存模块
