宜鼎国际SATA Slim 3SE-P嵌入式储存卡
产品分类:工控机 工控元器件 嵌入式系统 存储器 其它 工控机配件 存储产品 FLASH 存储产品
品牌:宜鼎国际
產品特色:
SATA III soultion for industrial field
DRAM buffer
Great I.O.P.S for best system reaction
iSMART disk health monitoring
Intelligent error recovery system
Excellent data transfer speed
Zero mechanical interference
Compatible with JEDEC MO-297 standard
產品介紹:
Innodisk SATA Slim 3SE-P is SATA III 6Gb/s Flash based disk, which designed with standard SATA interface (7+15 SATA connector), and compliant with JEDEC MO-297 standard. With its smaller dimension, SATA Slim 3SE-P is an alternative solution of 2.5” SSD for those embedded systemthat may have mechanical and space concerns. Innodisk SATA Slim 3SE-P operates under SATA III (6.0Gb/s) interface with excellent performance and reliability making it the ideal solution for a variety of applications, including embedded system, and industrial field.
規格:
產品料號:
宜鼎国际首创InnoEx虚拟I/O扩充模块 实现敏捷部署 推动AI应用高效落地
宜鼎InnoOSR一鍵還原固態硬盘
宜鼎国际DDR5 WT ECC UDIMM工业用闪存模块
宜鼎国际DDR5 WT ECC SODIMM工业用闪存模块
宜鼎国际DDR5 WT RDIMM工业用闪存模块
