宜鼎国际DDR4 WT DIMM VLP工业记忆体模组
产品分类:工控机 工控元器件 存储器 工控机配件 存储产品 FLASH
品牌:宜鼎国际
產品特色:
JEDEC standard 1.2V(1.14V~1.26V) Power Supply
JEDEC Standard 288-pin Dual In-Line Memory Module
8 bit pre-fetch
On Die Termination with ODT pin
Bi-directional Differential Data Strobe
SDRAM operating temperature range -40°C ≤ TA ≤ +85°C
Low profile of PCB
30µ" Gold Finger
RoHS Compliant
產品介紹:
Designed for industrial systems, Innodisk’s Wide Temperature DRAM modules are best suited for applications that must work in extreme temperatures. These modules use industrial-grade SDRAM components with 30µ" Gold Finger to ensure that the memory maintains its high-quality signal, even at temperatures as low as -40ºC or as high as85ºC.
規格:
宜鼎国际首创InnoEx虚拟I/O扩充模块 实现敏捷部署 推动AI应用高效落地
宜鼎InnoOSR一鍵還原固態硬盘
宜鼎国际DDR5 WT ECC UDIMM工业用闪存模块
宜鼎国际DDR5 WT ECC SODIMM工业用闪存模块
宜鼎国际DDR5 WT RDIMM工业用闪存模块
