宜鼎国际2.5" SATA SSD 3MG5-P固态硬盘
产品分类:工控元器件 工控机 工控机配件 存储器 固态电子盘 存储产品
品牌:宜鼎国际
產品特色:
2.5” SATA III solution for industrial field
7mm height mechanical design
High IOPS with 3D NAND solution
L³ architecture extends lifespan
RAID Protection
iData Guard for abnormal power failure
Built-in thermal sensor
iCell technology for data protection (optional)
iSMART disk health monitoring
產品介紹:
3MG5-P is innodisk’s first product series supported 3D NAND flash. Innodisk 2.5” SATA SSD 3MG5-P is characterized by L³ architecture and RAID engine with the latest SATA III (6.0GHz) ID204 controller. Innodisk’s exclusive L³ architecture is L² architecture multiplied LDPC (Low Density Parity Check). L² (Long Life) architecture is a 4K mapping algorithm that reduces WAF and features a real-time wear leveling algorithm to provide high performance and prolong lifespan. Innodisk 2.5” SATA SSD 3MG5-P is equipped RAID engine to offer additional level of data protection for exceptional reliability.
規格:
產品料號:
宜鼎国际首创InnoEx虚拟I/O扩充模块 实现敏捷部署 推动AI应用高效落地
宜鼎InnoOSR一鍵還原固態硬盘
宜鼎国际DDR5 WT ECC UDIMM工业用闪存模块
宜鼎国际DDR5 WT ECC SODIMM工业用闪存模块
宜鼎国际DDR5 WT RDIMM工业用闪存模块
