宜鼎国际DDR3 XR-DIMM工业记忆体模组
产品分类:工控机 工控元器件 存储器 工控机配件 存储产品 FLASH
品牌:宜鼎国际
產品特色
JEDEC Standard 1.35V(1.28V~1.45V) & 1.5V(1.425V~1.575V) Power supply
Wide Temperature SDRAM operating temperature range -40°C ≤ TA ≤ +85°C
Customized 300-pin connector for solid signal transmission
Equipped with 2 mounting hole to ensure the firm connection
RoHS Compliant
Support ECC function to immune to single-bit errors
Built-in temperature sensor
Specially made for aerospace & defense application, and other harsh environment usage
產品介紹:
In order to meet the high standards of the aerospace and defense industry, our XR-DIMM comes equipped with several advantages which will satisfy your expectation for robust DRAM modules. We offer DDR3 XR-DIMM, 4GB & 8GB, both with an integrated error checking and correction function. With its 300-pin socket connector, Innodisk’s XR-DIMM exceeds the pin number standard established by the SFF Special Interest Group (SFF-SIG), ensuring a firm connection between the CPU and DRAM module.
規格:
宜鼎国际首创InnoEx虚拟I/O扩充模块 实现敏捷部署 推动AI应用高效落地
宜鼎InnoOSR一鍵還原固態硬盘
宜鼎国际DDR5 WT ECC UDIMM工业用闪存模块
宜鼎国际DDR5 WT ECC SODIMM工业用闪存模块
宜鼎国际DDR5 WT RDIMM工业用闪存模块
