宜鼎国际SATADOM-ML 3IS4工业闪存模块
产品分类:工控机 工控元器件 存储器 工控机配件 存储产品 FLASH
品牌:宜鼎国际
产品特色
SATA III solution for Server Boot-Up Drive
Exclusive L³ architecture
DRAM-less, 100% data integrity
Excellent random performance
Designed with hardware LDPC ECC engine
Cost-effective Flash with iSLC
Cable-less through Pin 7/Pin 8 connectors
Hardware write protection supported
High less than 1U
Overview:
Innodisk SATADOM-ML 3IS4 is characterized by L³ architecture with the latest SATA III(6.0GHz) Marvell NAND controller. Innodisk’s exclusive L³ architectureis L² architecture multiplied LDPC (Low Density Parity Check). L² (Long Life) architecture is a 4K mapping algorithm that reduces WAF andfeatures a real-time wear leveling algorithm to provide high performance and prolong lifespan with exceptional reliability.
Innodisk SATADOM-ML 3IS4 is designed for server field. The high of the SATADOM suitfor 1U(44.5mm) high server, allow it to fit seamlessly into any server setup. Besides, the main benefit is going to be the ability tousea SATA boot device without using a drive bay.
The innovative Pin 8 uses the SATA connector itself as a power supply to drive the device without external cables. It could be connected directly to the SATA on-board socket on customer’s system without additional power cable. Besides, the booting time for operation and the power consumption is less than hard disk drive (HDD), and can work under harsh environmentcompile with ATA protocol, no additional drives are required, and theSSD can be configured as a boot device or data storage device.
规格:
产品料号:
宜鼎全面扩充边缘AI智能应用与智能存储 Computex 2024新品齐发、全新品牌主张亮相
宜鼎推出 iCAP Air 智能物联空气质量管理解决方案
宜鼎独创MIPI over Type-C解决方案突破技术局限,改写嵌入式相机模块市场样貌
宜鼎国际亮相第89届CMEF 积极推动AI智能方案的应用
宜鼎国际2.5" SATA SSD 3TS6-P AES工业用闪存模块
