宜鼎国际DDR4 RDIMM VLP工业用内存模块
产品分类:工控机 工控机配件 存储产品
品牌:宜鼎国际
产品特色
JEDEC Standard 1.2V (1.14V~1.26V) Power Supply
JEDEC Standard 288-pin Dual In-Line Memory Module
8 bit pre-fetch
On Die Termination with ODT pin
Bi-directional Differential Data Strobe
Average Refresh Period 7.8us at lower then TCASE 85°C, 3.9us at 85°C < TCASE ≤ 95°C
Support registered function
Low profile of PCB
Gold Finger 30μ"
RoHS Compliant
Overview:
The DDR4 LONG RDIMM VLP is a compact module that offers the industry's fastest memory speed with 2666MT/s, and it is fully compatible with the Intel® Purely platform and 1U devices. The modules come equipped with 30μ” Gold Fingers and include single bit error correction and a register to enhance clock, command, and control signals. All are available in 4GB, 8GB, 16GB, and 32GB capacities. 2133MT/s and 2400MT/s modules are also available.
VLP DIMM modules are specialized for use in 1U systems, such as blade server data centers, where system height is lower than 1.18 inches. The design of these modules improves airflow inside the system and reduces thermal impact.
产品规格:
产品料号:
宜鼎国际首创InnoEx虚拟I/O扩充模块 实现敏捷部署 推动AI应用高效落地
宜鼎InnoOSR一鍵還原固態硬盘
宜鼎国际DDR5 WT ECC UDIMM工业用闪存模块
宜鼎国际DDR5 WT ECC SODIMM工业用闪存模块
宜鼎国际DDR5 WT RDIMM工业用闪存模块
