进联MB622 PCB 一体式端子连接器
MB系列是利用押丝圈升降原理保证接丝牢靠,甚至是使用是薄的导线都能被适当地夹住,而且在环境较恶劣状况下(例如振动),这种接触状况也能够维持长时间稳定。
产品分类:电气连接 接线端子
品牌:进联
間距Pitch 5.00mm 5.08mm | 間距Pitch 5.00mm 5.08mm |
位數Poles 2 ~ 16Poles 2 ~ 16Poles | 位數Poles 2 ~ 16Poles 2 ~ 16Poles |
塑膠本體Housing Material PA 66 PA 66 | 塑膠本體Housing Material PA 66 PA 66 |
壓線圈Cage Clamp Brass, Ni Plated Brass, Ni Plated | 壓線圈Cage Clamp Brass, Ni Plated Brass, Ni Plated |
端子Contact Brass, Tin Plated Brass, Tin Plated | 端子Contact Brass, Tin Plated Brass, Tin Plated |
螺紋Screw Thread M2.6, Steel, Zinc Plated M2.6, Steel, Zinc Plated | 螺紋Screw Thread M2.6, Steel, Zinc Plated M2.6, Steel, Zinc Plated |
電線線徑Wire Size 14 ~ 26AWG 14 ~ 26AWG | 電線線徑Wire Size 14 ~ 26AWG 14 ~ 26AWG |
剝線長度Wire Strip Length 6mm 6mm | 剝線長度Wire Strip Length 6mm 6mm |
PCB孔徑PCB Hole Diameter 1.3mm 1.3mm | PCB孔徑PCB Hole Diameter 1.3mm 1.3mm |
最大緊固扭矩Tightening Torque, Max. 4.5 Lb-in 4.5 Lb-in | 最大緊固扭矩Tightening Torque, Max. 4.5 Lb-in 4.5 Lb-in |
環境作業溫度Operating Temperature -40˚C to +105˚C -40˚C to +105˚C | 環境作業溫度Operating Temperature -40˚C to +105˚C -40˚C to +105˚C |
TECHNICAL DATA
連接符合標準 | 連接符合標準 |
Connection in acc. with standard EN-VDE | Connection in acc. with standard EN-VDE |
額定電流 lN Nominal Current lN 16A 16A | 額定電流 lN Nominal Current lN 16A 16A |
額定橫截面Nominal Cross Section 1.5mm2 1.5mm2 | 額定橫截面Nominal Cross Section 1.5mm2 1.5mm2 |
最大負載電流Maximum load current 16A 16A | 最大負載電流Maximum load current 16A 16A |
絕緣材料Insulating Material PA PA | 絕緣材料Insulating Material PA PA |
阻燃等級,符合UL94 | 阻燃等級,符合UL94 |
Inflammability class acc. to UL94 V0 V0 | Inflammability class acc. to UL94 V0 V0 |
进联F25S1突出性照明防破坏开关环
进联F25S1圆顶式照明防破坏开关环
进联F25S1嵌入式照明防破坏开关环
进联F25S1突出性照明防破坏开关点
进联F25S1圆顶式照明防破坏开关点
