进联MH110 PCB接线端子台,高功率模块
MH系列为高电压高电流端子台,其材质符合欧盟之ROHS有害物质限用指令,采用耐撞击与防火耐燃等级UL9-V0的工程原料制造,更具有大线径特色,同时具备高扭力,使螺牙更不容易松脱.
产品分类:电气连接 其它
品牌:进联
MH110-016M PCB接线端子台,高功率模块
DIMENSIONS/POSITIONS | MH110-016M |
間距Pitch | 10.16mm |
位數Poles | 2 ~ 3Poles |
塑膠本體Housing Material | PA 66 |
壓線圈Cage Clamp | Steel, Zinc Plated |
端子Contact | Copper, Tin Plated |
螺紋Screw Thread | M4.0, Steel, Zinc Plated |
電線線徑Wire Size | 6 ~ 20AWG |
剝線長度Wire Strip Length | 10mm ~ 11mm |
PCB孔徑PCB Hole Diameter | 1.8mm |
最大緊固扭矩Tightening Torque, Max. | 20 Lb-in |
環境作業溫度Operating Temperature | -40˚C to +105˚C |
TECHNICAL DATA
連接符合標準 Connection in acc. with standard EN-VDE |
額定電流 lN Nominal Current lN | 57A |
額定橫截面Nominal Cross Section | 10mm2 |
最大負載電流Maximum load current | 57A |
絕緣材料Insulating Material | PA |
阻燃等級,符合UL94 Inflammability class acc. to UL94 | V0 |
額定電壓,UL/CUL Nominal voltage, UL/CUL | 300V |
額定電流,UL/CUL Nominal current, UL/CUL | 57A |
进联F25S1突出性照明防破坏开关环
进联F25S1圆顶式照明防破坏开关环
进联F25S1嵌入式照明防破坏开关环
进联F25S1突出性照明防破坏开关点
进联F25S1圆顶式照明防破坏开关点
