进联MH140 PCB接线端子台,高功率模块
MH系列为高电压高电流端子台,其材质符合欧盟之ROHS有害物质限用指令,采用耐撞击与防火耐燃等级UL9-V0的工程原料制造,更具有大线径特色,同时具备高扭力,使螺牙更不容易松脱
产品分类:电气连接 PCB连接器
品牌:进联
MH140-635 PCB接线端子台,高功率模块
DIMENSIONS/POSITIONS | MH140-635 |
間距Pitch | 6.35mm |
位數Poles | 2 ~ 8Poles |
塑膠本體Housing Material | PA 66 |
壓線圈Cage Clamp | Steel, Zinc Plated |
端子Contact | Copper, Tin Plated |
螺紋Screw Thread | M3, Steel, Zinc Plated |
電線線徑Wire Size | 8 ~ 18AWG |
剝線長度Wire Strip Length | 6.5mm ~ 7.5mm |
PCB孔徑PCB Hole Diameter | 1.6mm |
最大緊固扭矩Tightening Torque, Max. | 9.0 Lb-in |
環境作業溫度Operating Temperature | -40˚C to +105˚C |
TECHNICAL DATA
連接符合標準 Connection in acc. with standard EN-VDE | |
額定電流 lN Nominal Current lN | 57A |
額定橫截面Nominal Cross Section | 10mm2 |
最大負載電流Maximum load current | 57A |
絕緣材料Insulating Material | PA |
阻燃等級,符合UL94 Inflammability class acc. to UL94 | V0 |
額定電壓,UL/CUL Nominal voltage, UL/CUL | 600V |
額定電流,UL/CUL Nominal current, UL/CUL | 35A |
MH140-635M PCB接线端子台,高功率模块
間距Pitch | 6.35mm |
位數Poles | 2 ~ 30Poles |
端子Contact | Brass, Tin Plated |
TECHNICAL DATA
进联F25S1突出性照明防破坏开关环
进联F25S1圆顶式照明防破坏开关环
进联F25S1嵌入式照明防破坏开关环
进联F25S1突出性照明防破坏开关点
进联F25S1圆顶式照明防破坏开关点
