产品选型
进联SL4MC-27 面板安裝橫向滚轮行程开关
SL4MC半緊湊型封裝開關 High Utility Enclosed Switch
产品分类:
离散传感器 行程开关
品牌:
0.Characteirstics
Model
SL 4MC-07
SL 4MC-26
SL 4MC-27
SL 4MC -43
SL 4MC-44
SL 4MC-48
SL 4MC-60
SL 4MC-61
動作力因復力預行程過行程
應差距離
OF RF PT OT
MD
MAX MIN MAX MIN
MAX
5.88N
0.98N
1.6mm 5mm 02mm
5.88N
0.98N
1.6mm 5mm 0.2mm
5.88N
0.98N
1.6mm 5mm  0.2mm
1.96N
0 39N
5mm 3mm
2.94N
0 39N
2mm 1.5mm
2.94N
0.39N
2mm 15mm
1.67N
0.25N
4mm 3mm
2.55N
0.34N
2.5mm 17mm
自由位置動作位置
FP OP
MAX
218 12 mm
33.41.2mm
33.4 1.2mm
51mm
401mm
47mm
40 1mm
572mm
40 1mm
36mm
25 ± 1mm
33mm
25 1mm
保護結構 Degree of protection
IP67
壽命Durabilit
機械性 Mechanical
10,000,000 operations min.
電器性 Elect rical
500,000 operations min
容許操作速度 Operating Speed
0.05mm-0.5m/s
容許操作頻率Operatin Frequenc
機械性 Mechanical
120 operations /min
電器性 Electric al
20 operations /min
額定頻率 Rated Frequency
50/60Hz
絕緣阻抗(絕緣電阻) Insulation  Resistance
1OOMO min. (at 500 VDC)
接觸阻抗(接點電阻) Contact Resistance
15m0 max. (1nit1al value for the bu, It-in switch when tested alo ne )
耐電壓Dielectric Strength
同極端子間
Between terminals of same polarity
1,000VAC
50/60Hz for 1min
充電金屬部與接地端間
Between current-carrying metal parts and  ground
2,000VAC
50/60Hz for 1min
各端子與非充電金屬部誾
Between each terminal and non-current-carrying metal part
2,000VAC
50/60Hz for 1min
額定絕緣電壓  (,U )  Rated insulation voltage (Ui)
1000VAC
污染度(使用環境)  Pollution degree (Application environment)
3 ( IEC94  7-5-1)
額定開放熱電流 (Ith) Rated open thermal current(lth)
10A
觸電保護等Degreeof protection against electric shock
Class II
Vibration
振 動 Resistance
誤動作 Malfunction
10-55 Hz  1.5 mm double am,pI tude(雙振幅)
衝 擊 Shock Resistance
耐久 Destruction
1,000m max. (
誤動作 Malfunction
100m max. (最大)
使用環境溫度 Ambient operating temperature  range
-1 0~ +80°C with no icing ( 不結冰
使用環境濕度 Ambient operating  hum汕ty range
35~95%RH
包裝説明 Packing
1Op es丨Box
进联F25S1突出性照明防破坏开关环
进联F25S1圆顶式照明防破坏开关环
进联F25S1嵌入式照明防破坏开关环
进联F25S1突出性照明防破坏开关点
进联F25S1圆顶式照明防破坏开关点
