进联SL4MC-27SL4MC-27 臥式标准滚轮型行程开关
SL4MC半緊湊型封裝開關 High Utility Enclosed Switch
产品分类:离散传感器 行程开关
品牌:产品介绍
0.Characteirstics | Model | SL 4MC-07 | SL 4MC-26 | SL 4MC-27 | SL 4MC -43 | SL 4MC-44 | SL 4MC-48 | SL 4MC-60 | SL 4MC-61 | |
動作力因復力預行程過行程 應差距離 | OF RF PT OT MD | MAX MIN MAX MIN MAX | 5.88N 0.98N 1.6mm 5mm 02mm | 5.88N 0.98N 1.6mm 5mm 0.2mm | 5.88N 0.98N 1.6mm 5mm 0.2mm | 1.96N 0 39N
5mm 3mm | 2.94N 0 39N
2mm 1.5mm | 2.94N 0.39N
2mm 15mm | 1.67N 0.25N
4mm 3mm | 2.55N 0.34N
2.5mm 17mm |
自由位置動作位置 | FP OP | MAX |
218 士 12 mm |
33.4土 1.2mm |
33.4 土 1.2mm | 51mm 40士 1mm | 47mm 40 士 1mm | 572mm 40 士 1mm | 36mm 25 ± 1mm | 33mm 25 士 1mm |
保護結構 Degree of protection | IP67 | |
壽命Durabilit | 機械性 Mechanical | 10,000,000 operations min. |
電器性 Elect rical | 500,000 operations min | |
容許操作速度 Operating Speed | 0.05mm-0.5m/s | |
容許操作頻率Operatin Frequenc | 機械性 Mechanical | 120 operations /min |
電器性 Electric al | 20 operations /min | |
額定頻率 Rated Frequency | 50/60Hz | |
絕緣阻抗(絕緣電阻) Insulation Resistance | 1OOMO min. (at 500 VDC) | |
接觸阻抗(接點電阻) Contact Resistance | 15m0 max. (1nit1al value for the bu, It-in switch when tested alo ne ) | |
耐電壓Dielectric Strength | 同極端子間 Between terminals of same polarity | 1,000VAC 50/60Hz for 1min |
充電金屬部與接地端間 Between current-carrying metal parts and ground | 2,000VAC 50/60Hz for 1min | |
各端子與非充電金屬部誾 Between each terminal and non-current-carrying metal part | 2,000VAC 50/60Hz for 1min | |
額定絕緣電壓 (,U ) Rated insulation voltage (Ui) | 1000VAC | |
污染度(使用環境) Pollution degree (Application environment) | 3 ( IEC94 7-5-1) | |
額定開放熱電流 (Ith) Rated open thermal current(lth) | 10A | |
觸電保護等級 Degreeof protection against electric shock | Class II | |
Vibration 振 動 Resistance | 誤動作 Malfunction | 10-55 Hz 1.5 mm double am,pI tude(雙振幅) |
衝 擊 Shock Resistance | 耐久 Destruction | 1,000m max. (最大) |
誤動作 Malfunction | 100m max. (最大) | |
使用環境溫度 Ambient operating temperature range | -1 0~ +80°C with no icing ( 不結冰) | |
使用環境濕度 Ambient operating hum汕ty range | 35~95%RH | |
包裝説明 Packing | 1Op es丨Box |
进联F25S1突出性照明防破坏开关环
进联F25S1圆顶式照明防破坏开关环
进联F25S1嵌入式照明防破坏开关环
进联F25S1突出性照明防破坏开关点
进联F25S1圆顶式照明防破坏开关点
