进联SL4V-01 密封柱塞型行程开关
SL4V小型限位開關 Miniat ure Enclosed Limit Switch
产品分类:离散传感器 行程开关
品牌:产品介绍
O.Character |
Ist |
Ics |
| Model | SL4V-01 | SL4V-22 | SL4V-23 | SL4V-40 | |
動作力回 復 力 預行程過行程應差距離 | OF RF PT OT MD | MAX MIN MAX MIN MAX | 9.8N 2.94N 1.5mm 4mm 1.2mm | 9.8N 2.94N 1.5mm 4mm 1.2mm | 9.8N 2.94N 1.5mm 4mm 1.2mm | 5.88N 0.49N 20° 75° 1o" | |||
自由位置動作位置 | TTP OP | MIN | 5.5mm 26 士 0.8mm | 5.5mm 37 土 0. 8mm | 5.5mm 37 土 0.8mm | 95 " | |||
保護結構 Degree of protection | IP65 | |
壽命Durabilit | 機械性 Mechanical | 10,000,000 operations min. |
電器性 Elect rical | 300,000 operations min. (5A at 250VAC, resistive load) | |
容許操作速度 Operating Speed | 5mm~0.5m/s | |
容許操作頻率Operatin Frequenc | 機械性 Mechanical | 120 operations /min |
電器性 Electric al | 30 operations /min | |
額定頻率 Rated Frequency | 50/60Hz | |
絕緣阻抗(絕緣電阻) Insulation Resistance | 1OOMO min. (at 500 VDC) | |
接觸阻抗(接點電阻) Contact Resistance | 25m0 max. (initial value) | |
耐電壓Dielectric Strength | 同極端子間 Between terminals of same polarity | 1,000VAC 50/60Hz for 1min |
充電金屬部與接地端間 Between current-carrying metal parts and ground | 1,500VAC 50/60Hz for 1min | |
額定絕緣電壓 (,U ) Rated insulation voltage (Ui) | 250V | |
污染度(使用環境) Pollution degree (Application environment) | 3 (EN60947-5-1) | |
附帶條件短路電流 Conditionalshort-circuit current | 1OOA(EN60947-5-1) | |
額定開放熱電流 (Ith) Rated open thermal current(lth) | 5A(EN6094 7-5-1) | |
觸電保護等級 Degreeof protection against electric shock | Class I | |
Vibration 振 動 Resistance | 誤動作 Malfunction | 10-55 Hz 1.5 mm double am,pI tude(雙振幅) |
衝 擊 Shock Resistance | 耐久 Destruction | 1,000m (free position) m,n. |
誤動作 Malfunction | 300m (operation I imit position) min | |
使用環境溫度 Ambient operating temperature range | -2 0~ +60°C with no icing ( 不結冰) | |
使用環境濕度 Ambient operating hum汕ty range | 90%RH max | |
包裝説明 Packing | 5pcs丨Box |
进联F25S1突出性照明防破坏开关环
进联F25S1圆顶式照明防破坏开关环
进联F25S1嵌入式照明防破坏开关环
进联F25S1突出性照明防破坏开关点
进联F25S1圆顶式照明防破坏开关点
