智微智能E7QL视觉控制器
Intel 6/7th Core I3/I5/I7 处理器;双通道 SO-DIMM DDR4内存,最大支持32GB;支持SATA3.0 + M.2存储;支持双路Intel千兆网络
产品分类:机器视觉 其它
品牌:智微智能
Processor | Intel® 6/7 th Core™ i3/i5/i7 CPU,TDP 35W |
Chipset | Intel® Q170 |
Memory | 2 x DDR4 SO-DIMM 2400MHz,Max 32GB |
Storage | 2 x SATA3.0 1 x M.2 2242/2280 |
Graphics | Intel® HD Graphics |
Wireless | Mini PCIE for WIFI/BT4.0/4G Optional |
Network | 1 x RJ45,1000M 1 x RJ45,1000M ,Supoot POE 24V |
Audio | Realtek ALC662 HD Audio IC |
Interfaces Front side | 1 x SIM Card slot |
Interfaces Rear side | 1 x DC IN 4pin PHOENIX 4 x DB-9 COM, RS232 2 x DB-9 COM, RS232/RS422/RS485 2 x RJ45 10/100/1000M 1 x VGA out 1 x DVI-D out 1 x DP out 6 x USB3.0 Type-A 1 x Reset button 1 x Power button |
Expansion slot | 1 x MXM3.0 2 x PCIE 8X + 2 x PCI (1 x PCIE 16X +3 x PCI ) |
Power input | DC 9V~36V |
Watchdog | Support |
Dimension | 268mmx 194.2mm x 159.5 mm |
Material | Aluminium+SECC |
Working enviroment | Working temperture : -20℃~60℃ Storage temperture: -40℃~80℃ |
Relative humidity | 10%~90% ,40℃(non-condensing) |
【重磅新品】智微智能JEA-E88A,为移动机器人提供稳定可靠的硬件基石
面向工业机器人应用,智微智能JEC-2510紧凑无风扇工控机
重磅喜讯|智微智能成功在深交所主板上市
新品上市!性能与性价比兼顾,AIBOX让工业检测更灵活精准
打造过硬品质!智微智能触控工业平板电脑
