宜鼎国际InnoAGE M.2 2280工业用闪存模块
产品分类:工控机 工控元器件 存储器 工控机配件 存储产品
品牌:宜鼎国际
产品特色
Embedded Microsoft Azure Sphere
Hybrid edge/cloud solution
Out-of-band connection to Azure Cloud through Wi-Fi or Ethernet
Customized browser-run interface
Remote control enacted through onboard MCU
SSD supports GPIO, SPI, and UART
Innodisk data security
Power stability technology
Overview:
InnoAGE™ SSD with Microsoft Azure Sphere Inside
As a world-first, the InnoAGE™ SSD directly embeds Microsoft technology within an Industrial-grade SSD to achieve a hybrid edge/cloud solution.
With Azure Sphere inside, the InnoAGE™ SSD steps out of the traditional limitations of flash storage with a separate out-of-band connection with the Azure Cloud. This means unfettered connection to your SSD, even if the host system crashes. The Azure Sphere MCU directly gives the SSD commands and collects data.
This way there is always an easily accessible connection to your storage device to check status, run system recovery, implement security measures, or run data analysis. The SSD supports GPIO, SPI, UART for device communication, as well as Wi-Fi and Ethernet to connect to the Azure Cloud. The cloud connection is secured through sophisticated authentication methods.
The InnoAGE™ SSD is optimized for use in intelligent manufacturing, IoT Gateways, unmanned vehicles, surveillance, and digital signage applications.
规格:
产品料号:
宜鼎国际首创InnoEx虚拟I/O扩充模块 实现敏捷部署 推动AI应用高效落地
宜鼎InnoOSR一鍵還原固態硬盘
宜鼎国际DDR5 WT ECC UDIMM工业用闪存模块
宜鼎国际DDR5 WT ECC SODIMM工业用闪存模块
宜鼎国际DDR5 WT RDIMM工业用闪存模块
