宜鼎国际M.2 (P42) 3IE2工业用闪存模块
产品分类:工控机 工控元器件 存储器 工控机配件 存储产品
品牌:宜鼎国际
产品特色
PCIe Gen. III x2, NVMe 1.3
Excellent data transfer speed
Zero mechanical interference
LDPC ECC engine supported.
End-to-end Data Path Protection
Overview:
Innodisk M.2 (P42) 3IE2 is an NVM Express DRAM-less SSD designed as the standard M.2 form factor with PCIe interface and MLC NAND Flash. M.2 (P42)3IE2 supports PCIe Gen III x2, and it is compliant with NVM 1.3 providing excellent performance. Moreover, it adopts iSLC technology providing high endurance and reliability. With sophisticated error detection and correction (ECC) functions, the module can ensure full End-to-end Data Path Protection that secures the data transmission between host system and NAND Flash.
Innodisk M.2 (P42) 3IE2 is integrated with Marvell controller, which provide both low power consumption and efficient heat dissipation, making the SSD optimal for space-constrained IPCs and server boot-up applications.
规格:
产品料号:
宜鼎国际首创InnoEx虚拟I/O扩充模块 实现敏捷部署 推动AI应用高效落地
宜鼎InnoOSR一鍵還原固態硬盘
宜鼎国际DDR5 WT ECC UDIMM工业用闪存模块
宜鼎国际DDR5 WT ECC SODIMM工业用闪存模块
宜鼎国际DDR5 WT RDIMM工业用闪存模块
