宜鼎国际M.2 (P80) 3TE6工业用闪存模块
产品分类:工控供应链 存储器
品牌:宜鼎国际
产品特色
PCIe Gen. III x4, NVMe 1.3
DRAM-less Solution
Less Controller Heat
Anti-vibration mechanical design
Hybrid Write Mode
LDPC ECC engine supported
iPowerGuard Protection
Overview:
Innodisk M.2 (P80) 3TE6 is a NVM Express DRAM-less SSD designed with PCIe interface and industrial 3D TLC NAND Flash. M.2 (P80) 3TE6 supports PCIe Gen III x 4 and it is compliant with NVM 1.3 providing excellent top and also outstanding sustained performance. With sophisticated error detection and correction (ECC) functions, the module can ensure full End-to-End data path protection that secures the data transmission between host system and NAND Flash. In addition, with embedded AES-256 bit engine, your data can be further secured.
规格:
产品料号:
Innodisk丨M.2 2280 转四通道 GbE LAN 模块 EGPL-G401
邀请函丨共探AI前沿 宜鼎国际诚邀您共赴2025中国国际信息通信展
Innodisk|DDR5 CAMM2 / LPDDR5X CAMM2 单模块实现双倍带宽
Innodisk丨CXL 内存模组 赋能 AI 服务器的未来
焕新启航|宜鼎国际 Innodisk 全新简中官网正式上线!开启工业智能新篇章
