产品选型
宜鼎国际InnoAGE™ 2.5” SATA SSD 3TI7工业用闪存模块
2020/7/27 9:48:50
产品分类:
工控元器件 存储器
品牌:
宜鼎国际
产品特色
The World’s first hybrid SSD with an Azure Sphere inside
End-to-end security from edge to cloud
Hardware level allows easy and simple development
Supports out-of-band network management and diverse platforms
Supports wireless 2.4/5GHz dual-band 802.11 a/b/g/n Wi-Fi
Supports Ethernet
Overview:
The InnoAGE™ SSD comes with a Microsoft Azure Sphere inside, and is further integrated with Innodisk’s customized firmware, software, and hardware technology. This new solution enables multifunctional management: smart data analysis and updates, data security, and remote control through the cloud, while benefitting from the power of the Azure Sphere to guarantee secured communications between the SSD and the cloud.
The InnoAGE™ SSD delivers an easy-to-use interface with its customized cloud management platform. In technical terms, the Innodisk-developed firmware receives commands from the Azure Sphere via a second connection to Azure. Therefore, it is able to execute SSD debugging messages as well as monitor read/write behavior patterns to increase the storage device’s lifespan. Most importantly, system operators can quickly revert to the default settings from the cloud-based dashboard in the case of a device or system crash.
In other words, the InnoAGE™ SSD is designed for both in-band and out-of-band network management, providing full recovery even when the operating system has crashed or is severely impaired to the extent that in-band management would be of little help.
规格:
产品料号:
宜鼎国际首创InnoEx虚拟I/O扩充模块 实现敏捷部署 推动AI应用高效落地
宜鼎InnoOSR一鍵還原固態硬盘
宜鼎国际DDR5 WT ECC UDIMM工业用闪存模块
宜鼎国际DDR5 WT ECC SODIMM工业用闪存模块
宜鼎国际DDR5 WT RDIMM工业用闪存模块
