产品选型
宜鼎国际M.2 (P80) 3TE6工业用闪存模块
2020/10/19 16:11:07
产品分类:
工控元器件 存储器
品牌:
宜鼎国际
产品特色
PCIe Gen. III x4, NVMe 1.3
DRAM-less Solution
Less Controller Heat
Anti-vibration mechanical design
Hybrid Write Mode
LDPC ECC engine supported
iPowerGuard Protection
Overview:
Innodisk M.2 (P80) 3TE6 is a NVM Express DRAM-less SSD designed with PCIe interface and industrial 3D TLC NAND Flash. M.2 (P80) 3TE6 supports PCIe Gen III x 4 and it is compliant with NVM 1.3 providing excellent top and also outstanding sustained performance. With sophisticated error detection and correction (ECC) functions, the module can ensure full End-to-End data path protection that secures the data transmission between host system and NAND Flash. In addition, with embedded AES-256 bit engine, your data can be further secured.
规格:
产品料号:
宜鼎国际首创InnoEx虚拟I/O扩充模块 实现敏捷部署 推动AI应用高效落地
宜鼎InnoOSR一鍵還原固態硬盘
宜鼎国际DDR5 WT ECC UDIMM工业用闪存模块
宜鼎国际DDR5 WT ECC SODIMM工业用闪存模块
宜鼎国际DDR5 WT RDIMM工业用闪存模块
