宜鼎国际DDR4 RDIMM VLP工业用内存模块
产品分类:工控元器件 存储器
品牌:宜鼎国际
产品特色
Very Low Profile Specialized For Use in 1U System
Register for Enhancing Clock, Command, and Control Signals
Single Error Correction and Detection Available
Fully Tested and Optimized for Stability and Performance
Uses Original IC to Meet Strict Industrial Standards
Anti-Sulfuration Protection Against Harsh Environments
JEDEC Standard 1.2V (1.26V~1.14V)
Operating Environment : 0°C ~ 85°C
30μ” Gold Finger
RoHS Compliance
CE/FCC Certification
Overview:
DDR4 RDIMM VLP is a compact and a very low-profile module that offers the industry's fastest memory speed with 3200MT/s, and it is fully compatible with the Intel® Purely platform and 1U devices. The modules come equipped with 30μ” Gold Fingers and include single bit error correction and a register to enhance clock, command, and control signals. All are available in 4GB, 8GB, 16GB and 32GB capacities. 2133MT/s, 2400MT/s, 2666MT/s, and 2933MT/s modules are also available.
VLP DIMM modules are specialized for use in 1U systems, such as blade server data centers, where system height is lower than 1.18 inches. The design of these modules improves airflow inside the system and reduces thermal impact.
ECC modules are designed to detect and correct single-bit errors that occur during data storage and transmission. ECC modules use Hamming Code or Triple Modular Redundancy for error detection and correction, and manage error corrections on their own, without requesting that the data source resend original data.
规格:
产品料号:
宜鼎国际首创InnoEx虚拟I/O扩充模块 实现敏捷部署 推动AI应用高效落地
宜鼎InnoOSR一鍵還原固態硬盘
宜鼎国际DDR5 WT ECC UDIMM工业用闪存模块
宜鼎国际DDR5 WT ECC SODIMM工业用闪存模块
宜鼎国际DDR5 WT RDIMM工业用闪存模块
