宜鼎国际 M.2 (P80) 3TG3-P工业用闪存模块
宜鼎国际M.2 (P80) 3TG3-P工业用闪存模块
产品分类:工控机 工控机配件 存储产品
品牌:宜鼎国际
产品特色
PCIe Gen. III x4, NVMe 1.3
Excellent data transfer speed
High Endurance
Heat-spreading design
LDPC ECC engine supported
End-to-end Data Path Protection
Overview:
Innodisk M.2 (P80) 3TG3-P is an NVM Express SSD designed as the standard M.2 form factor with PCIe interface and industrial 3D TLC NAND Flash. M.2 (P80)3TG3P supports PCIe Gen III x4, and it is compliant with NVM 1.3 providing excellent performance. M.2 (P80) 3TG3-P go with a heat-spreading copper layer to dissipate heat generating from IC. With sophisticated error detection and correction (ECC) functions, the module can ensure full End-to-end Data Path Protection that secures the data transmission between host system and NAND Flash.
Innodisk M.2 (P80) 3TG3-P provides ultra-speed and high IOPS and offers maximum capacity up to 2TB, making the SSD optimal for server and heavy data workload applications.
规格:
产品料号:
宜鼎国际首创InnoEx虚拟I/O扩充模块 实现敏捷部署 推动AI应用高效落地
宜鼎InnoOSR一鍵還原固態硬盘
宜鼎国际DDR5 WT ECC UDIMM工业用闪存模块
宜鼎国际DDR5 WT ECC SODIMM工业用闪存模块
宜鼎国际DDR5 WT RDIMM工业用闪存模块
