产品特色
SD 3.0 interface
High performance
Power fail Management
BCH ECC algorithm implement
Overview:
Innodisk 3SE3 is an industrial-grade SD card solution with an integrated industrial controller, which is designed for embedded applications. With enhanced flash technologies and a powerful configurable BCH ECC engine, SD 3SE3 can achieve high-speed data transfer rates.
Innodisk industrial SD 3SE3 provides a wide range of capacities from 4GB to 32GB with MLC NAND Flash, and is fully compliant with SD3.0 and SD2.0 specifications.
Innodisk industrial SD 3SE3 are specifically designed for industrial PC and embedded applications for high performance. With its low power consumption and the above mentioned features, Innodisk industrial SD 3SE3 can be applied for industrial automation, SBC (single-board computer), medical equipment, infotainment, and mobile applications.
规格:
产品料号:
