宜鼎国际Industrial SD Card 3IE3工业用闪存模块
产品分类:工控元器件 存储器
品牌:宜鼎国际
产品特色
SD 3.0 interface
High performance
Power fail Management
BCH ECC algorithm implement
Overview:
Innodisk 3IE3 is an industrial-grade SD card solution with an integrated industrial controller, which is designed for embedded applications. With enhanced flash technologies and a powerful configurable BCH ECC engine, SD 3IE3 can achieve high-speed data transfer rates.
Innodisk industrial SD 3IE3 provides a wide range of capacities from 4GB to 64GB with MLC NAND Flash, and is fully compliant with SD3.0 and SD2.0 specifications.
Innodisk industrial SD 3IE3 are specifically designed for industrial PC and embedded applications for high performance. With its low power consumption and the above mentioned features, Innodisk industrial SD 3IE3 can be applied for industrial automation, SBC (single-board computer), medical equipment, infotainment, and mobile applications.
规格:
产品料号:
宜鼎国际首创InnoEx虚拟I/O扩充模块 实现敏捷部署 推动AI应用高效落地
宜鼎InnoOSR一鍵還原固態硬盘
宜鼎国际DDR5 WT ECC UDIMM工业用闪存模块
宜鼎国际DDR5 WT ECC SODIMM工业用闪存模块
宜鼎国际DDR5 WT RDIMM工业用闪存模块
