信步第8/9代Core平台网络安全主板NSE SVX-H31262
Intel 8/9代Core i3/i5/i7处理器, H310/C246芯片, 2*SFP, 6*LAN, 2组三代Bypass, 3*M.2, PCIe x8/x16, TPM
产品分类:嵌入式系统 物联网 嵌入式主板 应用层
品牌:信步科技
支持Intel 8/9代Core i3/i5/i7处理器
可选Intel C246/H310芯片
6*千兆电口, 2*千兆光口, 2组三代Bypass
提供可选的PCIe x8和PCIe x16插槽
3*M.2支持SATA, Wifi, 4G/5G
1*HDMI, 1*VGA
规格:
General | |
CPU | Intel® 8/9th Generation Core™ i3/i5/i7, Pentium®, Celeron® CPU, LGA1151 |
Chipset | Intel® C246/H310, TDP 6W |
Memory | DDR4-2666, 4*U-DIMM, up to 64 GB Support ECC with C246 chipset |
TPM | TPM 2.0 Onboard (optional) |
Storage | 1*M.2 (Key-M, 2242/2280, SATA SSD) 2*SATA 3.0, 1*CF Card |
Expansion Interface | 1*M.2 (Key-E, 2230, Wifi, only for C246) 1*M.2 (Key-B, 3042-4G, 3052-5G) 1*PCIe x8 Slot PCH PCIe x4, only for C246 Support one of the following 2 PCIe Side Plug Slot · 1*PCIe x16 Side Plug Slot CPU PCIe x8, PCH PCIe x4, 15*GPIO · 1*PCIe x8 Side Plug Slot CPU PCIe x4 |
BIOS | AMI UEFI BIOS |
System | Windows 10, Linux |
I/O Interface | |
Ethernet | 6*Intel® 1Gbps Ethernet Controller, RJ45 Support 2*Gen3 Lan Bypass 2*Intel® 1Gbps Ethernet Controller, SFP 2*SFP and PCIe x16 can not be supported at the same time when the chipset is H310 |
Serial | 2*RS232 |
USB | 2*USB 3.0, 2*USB 2.0 |
PS/2 | 1*PS/2 Header (Keyboard & Mouse) |
GPIO | 8 programmable GPIO |
Display | |
Display Interface | 1*HDMI: max resolution up to 4096*2160@24Hz 1*VGA: max resolution up to 1920*1200@60Hz |
Mechanical & Environment | |
Dimension | 288*207mm |
Power Input | ATX PSU |
Temperature | Operation: 0℃~60℃, Storage: -25℃~75℃ |
Relative Humidity | Operation: 10%~90%, Storage: 5%~95%, non-condensing |
把机器变成人,2023 信步开门红!
时延突破20微秒,信步再获创新三奖项!
信步工业边缘服务器主板SER SV-810
信步机器人控制器核心模块SAM-3588AH
2022,我们同舟共济创未来!
