宜鼎国际2.5” SATA SSD 3TV6-P工业用闪存模块
宜鼎国际2.5” SATA SSD 3TV6-P工业用闪存模块快
产品分类:工控机 工控元器件 存储器 工控机配件 存储产品
品牌:宜鼎国际
产品特色
InnoREC soultion for surveillance application
Exclusive REC line for video recording
Ensures steady performance without any frame-loss
Built-in thermal sensor
Support S.M.A.R.T, TRIM, NCQ and iData Guard
Overview:
Innodisk 2.5” SATA SSD 3TV6-P is the newest member of InnoREC product line, which adopts industrial Kioxia 3D TLC NAND. InnoREC is innodisk’s proprietary flash feature set designed specifically for surveillance applications. Through the smart integration of firmware and hardware, the speed and performance required by modern surveillance solutions are fully met. 2.5” SATA SSD 3TV6-P products provide high capacity flash memory Solid State Drive (SSD) that electrically complies with Serial ATA (SATA) standard. It supports SATA III standard (6.0GHz) with high performance and supports several features, including REC line, iData Guard, iCell, Quick Erase, Thermal sensor, passive cooling and S.M.A.R.T.
规格:
产品料号:
宜鼎国际EMPC-B2S1工控周边扩展卡
宜鼎国际InnoAgent EZ2N-0XL1工控周边扩展卡
宜鼎国际EGPC-B2S1工控周边扩展卡
宜鼎国际DDR5 WT UDIMM工业用闪存模块
宜鼎国际DDR5 WT SODIMM工业用闪存模块
