宜鼎国际M.2 (S42) 3TG6-P AES工业用闪存模块
宜鼎国际M.2 (S42) 3TG6-P AES工业用闪存模块快
产品分类:工控机 工控元器件 存储器 工控机配件 存储产品
品牌:宜鼎国际
产品特色
SATA III soultion for industrial field
Exclusive L3 architecture
AES-256bits encryption
Excellent random performance
Supports TRIM/NCQ/SMART
Built in iData Guard
Compatible with M.2 2242-D2-B-M standard
Designed with hardware LDPC ECC engine
Overview:
Innodisk M.2 (S42) 3TG6-P is SATA III 6.0 Gb/s flash based disk, which delivers excellent performance, especially in random data transfer rate, and which offers reliability making it the ideal solution for a variety of applications, including embedded system, industrial computing, and enterprise field. M.2 (S42) 3TG6-P not only performs unmatched performance, but also designed with Innodisk owned technical knowhow to ensure the data integrity and highest levels of reliability. Innodisk M.2 (S42) 3TG6-P is designed with AES engine, which is a built-in controller. When controller receives the data package from host, AES engine encrypts the data package and saves the encrypted data into NAND flash. Thus, unauthorized personal has no access to decrypt the data in NAND flash.
Innodisk M.2 (S42) 3TG6-P is designed for industrial field, and supports several standard features, including TRIM, NCQ, and S.M.A.R.T. In addition, Innodisk’s exclusive industrial-oriented firmware provides a flexible customization service, making it perfect for a variety of industrial applications.
规格:
产品料号:
宜鼎国际EMPC-B2S1工控周边扩展卡
宜鼎国际InnoAgent EZ2N-0XL1工控周边扩展卡
宜鼎国际EGPC-B2S1工控周边扩展卡
宜鼎国际DDR5 WT UDIMM工业用闪存模块
宜鼎国际DDR5 WT SODIMM工业用闪存模块
