宜鼎国际DDR5 WT SODIMM工业用闪存模块
产品分类:工控机 工控机配件 存储产品
品牌:宜鼎国际
产品特色
Small Outline Dual In-line Memory Module
Fully Tested and Optimized for Stability and Performance
Uses Original IC to Meet Strict Industrial Standards
On module Power Management IC (JEDEC Standard: 1.1V)
30μ” Gold Finger
Operating Environment: -40°C ~ 95°C
Anti-Sulfuration Protection Against Harsh Environments
RoHS Compliance
CE/FCC Certification
Overview:
The JESD79-5 DDR5 SDRAM specification has significant improvements in capacity, speed and voltage. By structure wise, the Power Management IC (PMIC) is moved onto the DIMM, reducing redundant power management circuitry on the motherboard for unused DIMM slots in previous generations.
DDR5 WT (wide temperature) SODIMM offers the industry's fastest memory speed with 4,800MT/s - the perfect fit for any in-vehicle, surveillance, automation and embedded application.
The modules comply with all relevant JEDEC standards, can operate in temperatures (TC) from -40ºC to 95ºC, and are available in 8GB, 16GB, and 32GB capacities.
规格:
产品料号:
宜鼎国际EMPC-B2S1工控周边扩展卡
宜鼎国际InnoAgent EZ2N-0XL1工控周边扩展卡
宜鼎国际EGPC-B2S1工控周边扩展卡
宜鼎国际DDR5 WT UDIMM工业用闪存模块
宜鼎国际DDR5 WT ECC UDIMM工业用闪存模块
