产品选型
宜鼎国际DDR5 WT ECC UDIMM工业用闪存模块
2022/11/9 22:47:43
产品分类:
工控机 工控机配件 存储产品
品牌:
宜鼎国际
产品特色
Single Error Correction and Detection Available
Fully Tested and Optimized for Stability and Performance
Uses Original IC to Meet Strict Industrial Standards
On module Power Management IC (JEDEC Standard: 1.1V)
30μ” Gold Finger
Operating Environment (TC): 0°C ~ 95°C
Anti-Sulfuration Protection Against Harsh Environments
RoHS Compliance
CE/FCC Certification
Overview:
DDR5 WT (wide temperature) ECC UDIMM offers the industry's fastest memory speed with 4,800MT/s - the perfect fit for any in-vehicle, surveillance, automation and embedded application.
The modules come equipped with 30μ”Gold Fingers, and another significant structural change is dual-channel DIMM architecture. For DDR5, each DIMM has two 36-bit channels (32 data bits plus using 4 ECC data bits). Two independent subchannels improve memory access efficiency, leading to greater speeds with higher efficiency.
The modules comply with all relevant JEDEC standards, can operate in temperatures (TC) from -40ºC to 95ºC, and are available in 16GB, and 32GB capacities.
规格:
产品料号:
宜鼎全面扩充边缘AI智能应用与智能存储 Computex 2024新品齐发、全新品牌主张亮相
宜鼎推出 iCAP Air 智能物联空气质量管理解决方案
宜鼎独创MIPI over Type-C解决方案突破技术局限,改写嵌入式相机模块市场样貌
宜鼎国际亮相第89届CMEF 积极推动AI智能方案的应用
宜鼎国际2.5" SATA SSD 3TS6-P AES工业用闪存模块
