产品选型
宜鼎国际DDR5 WT RDIMM工业用闪存模块
2022/11/9 22:43:46
产品分类:
工控机 工控机配件 存储产品
品牌:
宜鼎国际
产品特色
Register for Enhancing Clock, Command, and Control Signals
Single-bit Error Correction and Detection Available
Fully Tested and Optimized for Stability and Performance
Uses Original IC to Meet Strict Industrial Standards
On module Power Management IC (JEDEC Standard: 1.1V)
Operating Environment (TC): -40°C ~ 95°C
Anti-Sulfuration Protection Against Harsh Environments
30μ” Gold Finger
RoHS Compliance
CE/FCC Certification
Overview:
DDR5 WT (wide temperature) RDIMM offers the industry's fastest memory speed with 4,800MT/s - the perfect fit for any in-vehicle, surveillance, automation and embedded application.
The modules come equipped with 30μ”Gold Fingers, and another significant structural change is dual-channel DIMM architecture. For DDR5, each DIMM has two 40-bit channels (32 data bits plus using 8 ECC data bits). Two independent subchannels improve memory access efficiency, leading to greater speeds with higher efficiency.
The modules comply with all relevant JEDEC standards, can operate in temperatures(TC) from -40ºC to 95ºC, and are available in 16GB, and 32GB capacities.
规格:
产品料号:
宜鼎全面扩充边缘AI智能应用与智能存储 Computex 2024新品齐发、全新品牌主张亮相
宜鼎推出 iCAP Air 智能物联空气质量管理解决方案
宜鼎独创MIPI over Type-C解决方案突破技术局限,改写嵌入式相机模块市场样貌
宜鼎国际亮相第89届CMEF 积极推动AI智能方案的应用
宜鼎国际2.5" SATA SSD 3TS6-P AES工业用闪存模块
