当前页面: 首页 >供求信息 >Acopian VA5MT900电源模块
供稿:厦门兴锐达自动化设备有限公司 2011/12/20 14:52:54
0 人气:659
  • 型号:Acopian VA5MT900
  • 数量:10
  • 制造商:厦门兴锐达自动化设备有限公司
  • 有效期:2015/12/31 0:00:00
Chiron A-088977 Spindle for Chiron DZ12W Machine Center
Rohm 41496 SZS 45/92 Oil Operated Actuator w/Thru Hole
Adept Technology 90400-81021 EXC Controller Robot
Studer 2012.740 Hydrostatic High Pressure Spindle RH
Studer 2012.740 Hydrostatic High Pressure Spindle RH a
Dresser 418-J RAM WHISPAIR Rotary Blower
Peerless-Winsmi​th 183-18-0814-0 DC Servo Motor
FANUC Model 12S/6000 AC Spindle Motor
Adept Technology 90400-20035 Robot Module
Allen Bradley 1775-MEA B 64K Error Correcting Memory
Fanuc A06B-0753-B394-​R AC Spindle Motor
Mitsubishi HD101-12SP Permanent Magnet DC Servo Drive
Computer Conversions Corp HMR90-10SL 10-Turn Transducer
Okuma E0105-437-051 Operating Panel For OSF 500GLS
Camco 25S 7000LB Torque Overload Clutch - NIB
Set of 2 UVA U80-NN Slide "W" Axis Ball Assembly
Indramat DSC 1.6-50 DSC Drive -NOS
Yaskawa Type CACR ServoPack CACR-TS555Z1SRY​9 Motoman
Fanuc A06B-6058-H101 Servo Amplifier
Thermal Care AQ0A0204 2-Ton Air Cooled Accuchiller
TB Woods Volkmann 72350G1 Adjustable-Spee​d AC Drive
Yasnac (Motoman) JZNC-MPP22E MRC Teach Pendant - NIB
Indramat TMD2.1-030-300-​W1-000 24V AC Servo Controller
IEMCA 336109000 Board Scheda PLC Controllo Asse Boss
Landis Tool Co A99349 Remote I/O Mother Board Assembly
Fanuc A06B-0373-B077-​R AC Servo Motor
Yaskawa P Series AC Servo Motor USAPEM-03-YR11
Browning 215SMF25 Shaft Mount Speed Reducer
Allen-Bradley 1336F-BRF200-AN​-EN-HCS1-L4 AC Drive 20HP
Honeywell FF-SEDGE6G2-1 Category 3 Safety Laser Scanner
Allen-Bradley 1770-FEC PLC 3 Keyboard Module
TB Woods 76005G12 Drive
GTI Spindle Technology Micron Grinding Wheel Spindle
Allen Bradley 7300-UME-1 Feedback Module 7300UME1
Allen Bradley 8500 AID-KIB Servo Motor
Indramat MAC071A-0-OS-3-​C Permanent Magnet Servo Motor
GE Fanuc Automation A06B-0142-B188#​7008 AC Servo Motor
Giddings and Lewis 502-02728-00 Memory Interface Board
Cincinanati Milacron 3414331 SN109329 Eccentric Shaft
Reliance Electric 0-51893-7 FCCC Module
Reliance Electric P36G4902 60HP 1770RPM AC Motor
STK 304405013 PSCC Power Supply
STK 304405018 PSCC Power Supply
STK 304405014 PSCC Power Supply
Baumuller Nurnberg BUS21-15/30-30-​001 DC Servo Drive
Timken 39250-906A2 Precision Tapered Roller Bearing
Eatons Cutler Hammer C25LNE3360A 180MM Contactor
HK Systems 0060672001 Digital To Analog Converter Board
Fanuc A16B-1010-0285/​15B Zero BmasterPCB
Allen Bradley Bulletin 1391 AC Servo Controller
Computer Conversions HMR90-64HB Shaft Resolver
Mikron C100-FV-2P 110V Industrial Stator 169-5-0048-2
Heller 21004920 JK82DPS-IO Floppy Control - Used
Set of S.E. Huffman Rubber Way Covers for HS-75 Grinder
Computer Conversions MR90-64-HBSL Shaft Resolver
Adept Technology 10154-70200 PCA SFG Board
Gould Shawmut Amp-trap CL-14 Current Limiting Fuse
Yaskawa SGMP-02A8YR11 AC Servo Motor L Axis
GE D128 Tachometer Generator - New
Heller Machine Tool Uni-Pro 23-035336-005 Power Supply
Fanuc A06B-0315-B202 # 7000 AC Servo Motor
Allen Bradley 7300-UMA1 Feedback Module Spare
Computer Conversions Corporation HMR90-100Sl Transducer
IBM 300095509 AC Power Distribution Unit
Rexroth Variable Axial Piston Pump AA10VSO Series 31R
GE Fanuc 44A399742-G01 THC1D Circuit Card for 1050
Parker SX57-102 Compumotor
Millipore XX55 000 00 115V Vacuum/Pressure Pump - NIB
Fanuc A06B-6058-H223 Servo Amplifier
Price Pump CD100-VSS-494-0​14-25-18-3T6 Pump
Acomel 7114 C Chopper Board
GE Fanuc A06B-0314-B251 AC Servo Motor
Grundfos CR8-100U 4kW Multi-Stage Centrifugal Pump
Fanuc A06B-0142-B076#​7000 2000RPM AC Servo Motor
Allen Bradley PanelView 1400E Operator Interface Panel
GE Fanuc 44A399785-G02 PCI2A Board for Series 1050
Allen Bradley 1334-DJB Adjustable Frequency AC Drive
Mori Seiki T32057A03 Rotary Tool NA16 Collet Holder
Honeywell DCP7215C Programmable Controller
Giddings and Lewis 502-02771-50 Analog Interface Board
Cleveland Machine 402MNSP0S21 Servo Motor
Yaskawa Varispeed-616G3 General-Purpose Inverter AC DC
Allen Bradley 1775-MED A Error Correcting Module 128K
phd RS06 2x4-R2 Linear Pneumatic Slide - New
Mikron 169.5.0116.0 125V Assembly Spindle Motor Used
FANUC A-16B-3200-0412​/04A MAIN CPU BOARD
Cincinnati Milacron 3-531-3399A PCB Board
Electroid Co. 9 CB 560 Clutch-Brake Set -
Lincoln 82730 Power.masterAir Motor 4
Giddings and Lewis 572-02771-50 Analog Interface Board
Giddings and Lewis 502-02733-00 Math Board
Adept 01182-000 Dual C Amp
BMR GmbH SFU 0101 D Series Static Frequency Converter
Balcrank 1130-008 Giant Jet Stub Pump
Miller A77B4 Air/Hydraulic Booster Cylinder Accumulator
Fanuc A16B-1211-0310 PC Board
Allen Bradley 8500-E1F-KIB AC Servo Motor
SFJ H-2A Power Hold Center
Cincinnati Milacron 3-351-3600A I/O Expansion Board
Rotac / Micromatic MPJ-34-1V-OIL Actuator
Modicon AS-M484-100 Memory Board W/Batteries
GE Fanuc A06B-0314-B002#​7000 AC Servo Motor
Watlow D24SX5J Duct Heater
Speedfam Drum Assembly B467050 For Grinding Machine
Gettys A341-03 AC Servo Drive - Used
Servo Repair Int'l 403CLSPOS01 Servo Motor
GE Fanuc 44A398711-G02 0DI32B for Series 1050
Schatz 5413-1801 Torque and Torque / Angle Transducer
Marposs E9 Air Gap Amplifier for In-Process Apps NIB
Heller Machine Tool 23-035763 Analog Board
Yaskawa JANCD-BB03 Main Board
DEC DRV11-J 64-Line Parallel Interface M8049
PHD SGBM56X760-BB-C​B-H39 Slide w/Rodless Cylinder
BOC Edwards WV5D1B111 Electro Numeric Gate Valve
Price Pump CD100-VSS-400-0​14-100-36-3T6 Pump
Giddings and Lewis 502-03055-00 Servo Board
GE Fanuc 44A398714-G02 PERI1H Board for Series 1050
Automated Finishing 1W1000007700 Adjustable Idler
Raycon 302139 Power Switch
Raycon 302139 Power Switch - Used
Midwest Pressure Systems AA001 Bootstrap Compressor
Westinghouse Series A251 Size 2 Reversing Contactor
Michigan Custom Machines 1341-104 Cam Lobe
Schatz 5413-1800 Torque and Torque / Angle Transducer
Fanuc A06B-0373-B575 #7008AC Servo Motor
Fanuc A06B-0373-B077 #7008AC Servo Motor
magneta 14VDC Magnetic Particle Clutch Type 14.502.04
Allen Bradley 1326-DPA4B DC PM Servo Motor
Giddings and Lewis 502-03061-01 Processor Module
Giddings and Lewis 502-03061-51 Processor Module
Giddings and Lewis 502-02721-50 ALU Board
Allen Bradley 1336S-EN4 5 HP AC Drive
Giddings and Lewis 502-03061-02 Processor Module
Heller Machine Tool 23.020036 CUS Board
Allen Bradley 1771-OFE1 Analog Output Module
Mistubishi MR-J40A-UL 3 Phase AC Servo Amplifier
Kollmorgen BDS4 Servo Amplifiar
Gridley BM838040 Double Deck Dovetail Tool Holder
Robohand DLT-30M-R-B-150​S Direct Connect Block Thruster
Kollmorgen 00-00907-002 Type U9M4T Servodisc DC Motor
Allen-Bradley 1326DS-L4D-FL-E​1 DC Servo Motor w/Encoder
Buckeye Cooper Power Tools BMN-3536 Air Motor
Kooltronic KA4C4NP36L Panel Mounted Air Conditioner
IDC NH102B-6-MF1-MT​1 Electric Cylinder
Balluff BNS 519-D16R12-100-​10 16-Position Limit Switch
Fanuc A16B-2200-009/0​6A Axes Control Board
Kollmorgen 00-00902-002 Type U9M4T Servodisc DC Motor
Hanchon 1300489 73760 Hydraulic Cylinder
Reliance Electric 86474-8S Rectifier Stack
Allen Bradley 1785-KA Communication Adapter Module
Parker S8-Servo Drive Microstep
Sony Magnascale MSS-201B Encoder - NIB
Modicon AS-B827-032 Input Module - Used
CMC 402CNSP0S57 Permanent Magnet Servo Motor
Traub 727462 Joint Shaft
Knoll TG40-20/22 Coolant Rotary Pump
Okuma A005-4263-800 Motor
Osborne 13809 20" Wheel Brush
Collet Chuck Assembly
Lot of 36 Yillik Precision Industries 1231895 Bushings
NSK W3206WF-80PSI-C​3Z5.08 Precision Ball Screw
Lambda LMS-9018 0-18VDC Regulated Power Supply
Allen Bradley 900211-92 Encoder Card
ROTEX 38/45 GS COUPLING
Allen-Bradley 1305-BA06A Adjustable Frequency AC Drive
Hub City Model 3204 Worm Gear Speed Reducer
Adept Robot Arm Signal and Power Cables Set of 2 Cables
Bosch 981023 Hydraulic Valve & Manfold Max psi 3000
ARO Model 8235-5 0-Series 1600 RPM Power Motor - NIB
CutlerHammer D520APJ Directrol Multiplexer Power Supply
Ind Drives / Kollmorgen TT-2952-1210-A DC Servo Motor
Cincinnati Milacron 3282190-01 Core Memory Module
Adept Technology 10846-13430 Robot Signature Card w/box
GE Fanuc 44A399759-G01 AD256B PC Board
Reliance 0-48673-1 104/105 Regulator Board
Mikron 111.2.1276.0 Multiprocessor Interface Memories
Giddings and Lewis 502-03064-00 Digital I/O Board
PHD RS062X1 Slide&Cylinder Combo
Mikron 983-302-267 Transformer 3x380
Allen Bradley 512-AJB-3E-5R-6​P-24R Starter w/Disconnect
Giddings and Lewis 502-02721-00 ALU Board
Giddings and Lewis 502-02722-00 Address Generator Board
Giddings and Lewis 502-02823-00 Memory Interface No. 2
Ward Leonard RPD9-20100 260A Definite Purpose Contactor
Heller Machine Tool 23-0200-62 AMUB 49 Control Board
Cognex 800-5740-1 In-Sight 1000 Processor Camera System
Price Pump XT100SS Series Pump
Mitsubishi Electric HA33NC-S AC Servo Motor
IDC NX-10-2B-6-MF1-​MT1-34X Electric Cylinder
MCG 44-MT1765 Motor
Yaskawa CPS-18F Yasnak DC Power Supply
Psytronics P4801 480V Transient Voltage Protection Sys
ALBE SA 111212760 Multiprocessor Interface CPU Memories
Hoerbiger-Origa 25J2220/20X43.8​7BM Pneumatic Cylinder
Heller Machine Tool 23-032304 Circuit Board
N.E.A.T Slide XY 3x12 for XY Slide Assembly - Used
Gettys A111-03137-H04 60A DC Servo Drive
GmbH Di-Soric OGW 150 P2K-TSSL FrameLight Barrier PNP
Pacific Scientific E42HLFC-LNK-NS-​00 Step Motor 1.8
Mitsubishi FX562A CNC Module FX562
NSK Precision LTD M-E1020-014 Megatorque Motherboard
Control Techniques DB220 Digit AX Brushless Servo Drive
Giddings and Lewis 502-03063-01 Communication Board
Hoerbiger-Origa 50-2021-20-BM Rodless Cylinder
Fanuc A06B-0128-B575 AC Servo Motor
Fanuc A06B-0128-B577 #7076 AC Servo Motor
Emo Kamenz GMBH GHTS-42 Feed Back Tachometer
Amicon TPY2-304A-3HP Typact DC Drive - Spare
IBM STK 300096111 Power Supply BCU01
Giddings and Lewis 572-02722-50 Address Generator Board
Giddings and Lewis 502-02722-50 Address Generator Board
Heller Machine Tool 23-020018 Adapter Board
Giddings and Lewis 572-02721-50 ALU Board
Siemens 6FX-1121-2BA02 Series 810 Interface Card
Mitsubishi BN624A283H04 CNC Module
Galil Motion Control DMC-1020 2 Axis With Strap
Stromag C1G-030-1BE Motor Controller - Used
Marco Elect. 66PKV6L1 1050 RPM Type V-6 Electric Motor
PCB Piezotronics 116B High Pressure Temperature sensor
Cincinnati Milacron 3-531-3221A Disc System Interface
Heller 23.020.103 28-Slot Rack Back Plane Module
Heller A 23.032.248 10-Slot Rack Back Plane Module
Heller A 23.032.248 10-Slot Rack Back Plane Module A
Adept 90400-60131 300W Controller Amplifier
Rohm 41496 SZS 45/92 Oil Operated Actuator - Used
Allen Bradley 7300-UAE I/O Multiplexer Module
Sony Magnascale MSD-701-1 Detector With Cables - NIB
SOLA HT5F6AS 30073355 Hevi-Duty Transformer
Giddings and Lewis 502-03093-00 CMOS Dual Bus Memory
Kollmorgen Ind PSR4/5A-112-000​2 Power Supply
Giddings & Lewis 502-02723-83 CPU Control Board - Used
Lot of 48 Carboloy SNMG 433E48  2556-0211
Allen Bradley 8600-F18C Axis Manager CPU Module
Kollmorgen Ind PSR4/5A-112 Power Supply
Lot of 18 Pall Filterite ARD 40-40US-M3 Filter
Gusher 11021-Short Pump
Allen-Bradley 1771-PA Power Supply
Giddings & Lewis 502-02731-50 Logic I/O Board - Used
Copeland CRD1-0200-TFD-9​70 Hermetic Type Compressor
Honeywell Sensotec 060-H063-01 Mod. PPG Pressure Sensor
Raycon 300808 Regulator Interface Board - NEW
Hoerbiger-Origa 50-2021-20X 27BM Rodless Cylinder
Heller Machine Tool 23-020061 Power Board
Enerpac B-3006 Air/Hydraulic Booster
Allen Bradley H-3016-N-1-100A​A AC Servo Motor
API-Harowe 11BRW-300-M-10B Brushless Resolver Sensor
Reliance Electric 2DB4020 VS Drive Dynamic Braking Kit
Fuji Electric MGA42A0025050U 3-Phase 200W Geared Motor
Allen Bradley 512-AJB-3-6P-24​R 480V Enclosure 3R/4/12
Reliance Electric 0-51884 LSCA Module
Reliance Electric 0-52808 OLVA Overload Relay Module
Giddings&Lewis 502-02165-00 Rotation Direction Detector
Westinghouse HMCP030H1C Motor Circuit Protector Breaker
Marposs 6321610703 4X8K8 + 1X8K8 EEPROM + BAT CMOS Card
GE Fanuc 44A399750-G02 PS106 Board
Heller Machine Tool 21-004940 Video Graphic Board
Heller Machine Tool 21-004940 Video Graphic Board A
AMCI 7561 SSI Interface Module - Allen-Bradley SLC500
GE Fanuc 44A394683-G01 Tradic Circuit Board
Raycon 1524 Collet Guide
Heller 23.020.026 20-Slot Rack Back Plane Module A
Crown 60030-70 Washer
Allen Bradley 1336S .75 HP AC Drive 1336S-BRF07-AN-​EN4
Omron C40H-C6DR-DE-V1 Programmable Controller
phd RA Series RAS140X90-M-NB-​Q10 90 Deg Rotary Actuator
Sunnen CGT 7-236-D5-X1 SuperAbrasive Krossgrinding Tool
GE 9F60 HJD125 Fuse Type EJ 0-1DD Amp 125E
Reliance Electric 45C15C Programmable Controller -
Mitsubishi MR-J2-10A-K08 3 Phase AC Servo Amplifier
ROCKWELL-EQUIME​TER 122-8-1 1/4 REGULATOR
GILMAN "V" JAW, L.H.+
Fanuc A16B-1200-0742 PCB 2 Axis Sub Micron Sensor Board
Allen Bradley 852S-NSB Solid State Timing Relay
Tsubaki C-2082 10' 3.048mm Stainless Steel Roller Chain
Balluff BRGBO-WAB-12-EP​-P-R-K-0.5 Shaft Encoder
GE Fanuc 44A398710-G01 BKPN7 Board
Square D I-Line PQ-3610G 100A 600V Plug-In Unit
Kaman 853423-02M Position Displacement Sensing System
Giddings and Lewis 502-02724-51 Console Interface Board
Mitsubishi FX52C CNC Module
Giddings and Lewis 572-02778-50 Universal CRT Interface
Giddings and Lewis 502-02724-01 Console Interface Board
Giddings and Lewis 502-02778-50 Universal CRT Interface
Sensotec 41/0572-01 2000 LBS Tension Load Cell
Allen Bradley 150 SMC 500-1000 Amp Control Module
Square D KAL36225 Circuit Breaker
Heller Machine Tool 23-020013 Cam Board
Westinghouse HMCP150T4C Motor Circuit Protector
Giddings&Lewis 502-02707-00 Output Interface Board
Motion Engineering LC/DSP 4-Axis Motion Control
Rofin Baasel Lasertech 601-09740 BL6 Resonator Part
Jefferson Electric 213-0107-055 Transformer
Siemens 6FX1818-0BX02 EPROM Module - 810 Spare Board
Heller Machine Tool 23-020041 Connector Board
Fanuc A20B-1002-0740 Power Supply Board - New
Norgren A0477C1 REV #3 Pneumatic Cylinder
Mitsubishi MR-J10MA-UL 3 Phase AC Servo Amplifier
Marposs 6316160600 15V AC/DC Feeder for E14 Amplifier
Allen-Bradley 6632-MBSA Modem SEALED
Grundfoss 653864602302 Multistage Centrifugal Pump
Allen Bradley SMC-2 150-A09NB Smart Motor Controller
Okuma E4809-770-033-1 Relay Card
Automation Inc. D0026 Folder/Scale Board
Hub City 0220-66951-2104 Model 2104 Reducing Gear Box
Grove Gear Flexaline BMQ220-2 Worm Speed Reducer
Graco 178900 Sleeve
Oriental Motor Super Vexta UD519 5 Phase Motor Driver
Giddings and Lewis 502-02748-01 Valve Driver
Kollmorgen Ind PSR4/5A-112 Power Supply Rebuilt
Reliance Electric IRCG DC Drive Relay Module 0-51839-8
Mikron SA Agno 169-3-0001-B Rotor
Marposs 63213215500 E14 RAM Card - NIB
Omron Programmable Controller 3G2C4-SI Expansion Unit
Reliance Elect P25S3029 AC Motor 15 HP Three-Phase
Oval Strapper 2D597-3 Balance Fly-Wheel
Acme TF-2-49873-S 3KVA General Purpose Transformer NIB
Timken 42350 90067 Matched Tapered Bearing Assembly
ASCO 8342C-020 Solenoid Valve
Sensis Corp BBCF1410 Fixed Mount Bumpy Barcode
Beta Tech Inc BC-FSC-050-004 Input Board
Fanuc Drive A20B-1003-0080 Power Control AC Servo Board
Stearns Rexnord 87000 Series Self-Adjust Brakes - New
Eaton-Kenway Doo60672 Digital to Analog Converter Board
Reliance Electric P56X2002P 1 HP 1725RPM AC Brake Motor
Mitsubishi FX63A CNC Module FX63
Cincinnati Milacron 4-531-4004A00B Interface Module
VEE-ARC PC7000-10 Regulator Board 404-039 L
Siemens 6FX1128-1BA00 PCB Memory Board
Reliance Electric P18G4901EC 5HP 3475RPM AC Motor
Thermal Care 960-0169 Std Fitted Model 16 Motorpump
Allen Bradley 1771-SDN Series B Devicenet Module NIB
Control Techniques 9600-6400 Dominax DD400 5HP Drive
Giddings & Lewis 502-02722-50 Address Generator Board
Rapid Electric PC72 Cat Printed Circuit Board P.C. 72
GE 5BC48JB830 1.2HP 2550 RPM DC Motor
General Electric 5KS213SAB205A 7.5HP 1770RPM -NIB-
PARKER PR3MM Pressure Reducing Valve
25 Saturn Precision Brass Rod Electrode .0121 X 12"
ASCO 8344B48 Double Valve
Square D KAL36225 Circuit Breaker - Used
Price Pump CD 100 SS CD100SS Pump End Only
Square D 5S1FIS 5.0 KVA Insulated Transformer 156908
Fanuc A20B-0008-0242 PC Board
GE Fanuc 44A398712-G01 PC Board IFI32 for 7500
Allen Bradley 512-BJB-3E-5R-6​P-24R Starter w/Disconnect
Cincinnati Milacron 3-531-3180A Jumper Board
Digital M8049 64 Bit Parallel I/O Module
Banner Engineering MGR2416A Light Curtain Receiver
Reliance Electric 0-51839-8 IRJC Board
Acme-Gridley Pully Shaft for 5/8" Acme Bar Machine
Cognex 800-5740-1 Rev. K In-Sight 1000 Processor Camera
1910-3132 Small Grinder Part 702 495 53
Siemens 548-258-9102 CPU Board For System 810
Lexmark 16A0553 X433/X443 MFP Option - New
Vickers DG4S4-012N-115A​C50-51 Double Solenoid Valve
25 Saturn Precision Brass Rod Electrode .01229 X 12"
PHD 302578-03 Hoerbiger-Origa 72309-0303 Cylinder
SKF NN3016 KTN/SPW33 CYLINDRICAL ROLLER BEARING
Miller Coax MK-15-NC-14-15-​C1-1/2 Solenoid Valve
Leeson C6T17FC111F AC Motor 1/2 HP 1725 RPM
Circle Seal Controls SV462A32P6P39 Solenoid Valve
Stromag 04-04907 SAF.9 100V .23 Amp Brake
Marposs 6321321500 Shared RAM Memory Board
Shawmut A4BT1600 Time-Delay Fuse
Sundstrand 65001223 EFM-G1 Control Board
Bijur Type D3156 TM-5 Automatic Cycle Lubricator
Magnatrov M036527 Valve 50PSI 45Watts 120V 60Hz 2" Pipe
FAFNIR/TORRINGT​ON 2MM911WI DUL EXTRA PRECISION BEARING
GE 5KCP39CG 1000/870/750 RPM 1/20 HP Electric Motor
Okuma E4809-770-032-2 Relay Board
ASCO 8300D61U SOLENOID VALVE
Festo DGO-1 5/8"-54-HA Rodless Pneumatic Cylinder
Allen Bradley 7300-UDB-3 Output Module
Giddings and Lewis 502-02723-52 CPU Control Board
Lintech SA-2096-E2 Shaft Assembly SA2096E2
Cincinnati Milacron Paper Tape Interface Board
Lot of 450 Speedfam Sleeve For Speedfam 10WD0047
Baumuller GSF 56-S Servo Motor
Reliance Electric 86474-7S Thyristor Assembly
Okuma H1014-0007-64 Ball Screw for Okuma LB9 Lathe
Omron C200H-OD215 Output Unit -
Vickers SA4-06 Series Servo Valve
Continental Hydraulics PVR15-15B15 1500 PSI Vane Pump
Danfoss 04205 1 HP 1800 RPM Permanent Magnetic DC Motor
Lexmark 16A0400 OptraImage X433/X443 MFP Scan Unit
Allen Bradley 700-NT400A1 Type N Timing Relay
Oneac CX1000 Power Conditioner
Muller 120V1H03 DC Drive
Telemecanique RM3 JA102MW Current Measurement Relay
Allen Bradley 700-RTC00110V1 Solid State Timing Relay
Cutler Hammer D60LT3 Current Sensing Relay Transformer
Hiwin Tech 9812963004 Ball Screw 6 X 6 Working Stroke
Ophir 1201400 AN/2 Display for Ophir Thermal Hands
Allen Bradley 1775-MEA 64K Ram Memory
Kuroda Precision RX300042-1 J1 Ballscrew 1000, XM3
Crizaf 0270366AFYE0000​00 ES/2 UO/U2 Conveyor Belt
Grundfos MOT MG 71B2-14FT85-C Motor
Omron C200H-CT001-V1 Counter Unit
Reliance Electric P56X7258M .5-HP 1725 RPM AC Motor
Giddings & Lewis 502-02804-50 EIA Interface Board
Westinghouse 5ACLS-5R 5.08KV 150A 60Hz Fuse
Reliance Electric SP120 S12-403P8LU 2HP AC Drive
G&L 502-02777-50 Digitizing Interface Board - Used
Giddings & Lewis 502-02724-51 Console Interface Board
BANNER MSE2024Y MINI-SCREEN SAFETY LIGHT CURTAIN
Hayes DA-21012-C Driver Amplifier
Landert-Motoren 63-MK-FA4C AC Motor
GE Fanuc 44A397853-G01 TODI/A Card
Banner USCD-1T2 Mircro Control Box
Reliance Electric 10XW4011 VSM500 Speed Drive w/Motor
Price Pump F50AI-369-6A211​-50-36-3T6 1/2 HP Baldor
Computer Products 021-5222 AC Input Module
GE Fanuc IC693MDL751CA Output Module 12/24 VDC 32PT NIB
Westinghouse HMCP070J2C Motor Circuit Protector Breaker
Cincinnati Milacron 3-351-3291A Monitor Control Board
Cincinnati Milacron 3-351-3628A Slide Driver CPU Board
Escort Memory Systems HS900-4 Controller Board
Parker SS60105001 Double Solenoid Valve
G&L 502-02718-50 Universal CRT Interface Board - Used
Numatics V1211400900MOO Rodless Locking Cylinder - Used
Gould Shawmut Amp-trap CS-3 A550X200E-1 Fuse
Symbol LS4006I-I100 Scanner
Fasco 066541501 1500/1400 RPM 1/20 HP Electric Motor
GE 5KCP29FK 1540/1150 RPM 1/10 HP Electric Motor
Raycon 30-730044-Rev B Micropulse Backplane - NEW
Baldor 35L486X945G1 1-HP Stainless Steel AC Motor
WEB Printing 800-136-00 Motherboard
A.O. Smith DE3G047N 1050 RPM Electric Motor
GE 44A398716-G01 TRAD2A Board 44A398716G01
Westinghouse A201K1CA Non-Reversing 27-Amp Contactor
Allen-Bradley 1494F-NF100 Disconnect Switch
Muller 120V3H03 DC Drive
Pacific Scientific R33 GENC-HS-ND-NV-0​0 Servo Motor
Superior Electric M091-FF-206C5 Slo-Syn Motor
Marposs 6421610100 E14 Magazine Memory Card 4X16K
SUPERIOR ELECTIC M091-FF-206C5 STEPPING MOTOR
Magnetek CE3F011N 1100 RPM Electric Motor
Boy Machines SB54 Digital Display Board - Used
Boy Machines SB53 Digital Display Board - Used
Koganei MRGH20X200 Slide
Allen-Bradley 1771-IXE/A Thermocouple/Mi​llivolt Module
GE Fanuc 44A397889-G01 CG5D Board For 550
Landis A99304 MPC-FDI Board
Okuma Opus 5000 E4809-032-452-C EC Board
GE Fanuc 44A399752-G02 REG11Board for Series 1050
Marposs 6349340100 Electric Retraction Module
Norton Alundum Grinding Wheel 57A80-RR51
Racine 951940 Driver Board
EMC Clariion 005348430 Main Board Assembly
Cincinnati Milacron 4-531-4020A PCB Board
Cincinnati Milacron 3-531-3490A Slide Driver Board
Pair of Fafnir 2MM9112WI CR DUL SuperPrecision Bearing
TB Woods BY48SAA BY Spacer Sub Assembly CL A
Allen Bradley 1785-LT PLC-5/15 Processor Module
Mace M0-170BQ 17" Black & White Security System
Giddings and Lewis 502-03113-00 Power Supply and Driver
Yaskawa JANCD-CP11 CPU Board
Heidenhain 251-681-79 Encoder
Gould/Modicon AS-W600-006 Cable Assembly
Westinghouse A201K2CA Model J Non-Reversing Contactor
SCHUNK OSE-A34-4 ROTATE UNIT
Fafnir 3MM212WI DUL Super Precision Ball Bearing NIB
Parker GAW151P-A81V-A Actuator Gripper 150 PSI
Baldor CM3613T 5HP AC Motor
Burks Pumps H22CW0526 T315GA5-1-AI-MV Centrifugal Pump
GE 5KCP39DG 1075 RPM 1/8 HP Electric Motor
GE 5KCP39BG 1000/870/750 RPM 1/20 HP Electric Motor
Emerson Electric Model WC1004 DC Motor Unused
Allen-Bradley 6632-MBSB Modem
Acopian VA5MT900 Regulated Power Supply
Bussman JCL-A-4R Fuse 130A 60Hz
Sensotec 43/0825-02 Load Cell 100LBS 10VDC
Norgren A1277C1 Rev 3 Actuator
Winter 1919-3402 Diamond Dressing Roller
Adept Technologies 13200-00040 FIB Sensor Cable
  • 电话:0592-5580706/13295922579
  • 传真:0592-5361297
  • email:LJY_05228@163.com
更多内容请访问 厦门兴锐达自动化设备有限公司(http://c.gongkong.com/?cid=52360)
猜你喜欢
    类似产品
    换一换
      看过的用户还看过
      换一换
        历史浏览记录
          登录注册可查看更多历史记录
