- 型号:Fisher XT-3000
- 数量:10
- 制造商: 厦门兴锐达自动化设备有限公司
Taylor-Wharton 10 Liter Liquid Nitrogen Cryogenic Dewar Cap
Gast Regenair Blower Model R4P315A
Gast Model R3305A-1
Gast Model 2067-V103
Aerzen GMb 16.13 HV Roots Blower Vacuum Pump 11,700 M3/Hr. Excellent Condition
Noyes OFL-100HR
Grandville-Phillips Model 260015
Fisher XT-3000
Taylor-Wharton 5 Liter Liquid Nitrogen Transport Dewar Cap
LMQ II Infinity Solutions Integrated Folder/Sealer Paper
Neutron REM 500 Servey
Taylor-Wharton 35-50
Laser Diode Aray SDL 34-00332
HPS KF40 Shut-Off MKS
EMG 97 Lambda Physics Power Supply Hewlett Packard
ARC Monochromator Spectrometer Parts/Rebuild Spectra Physics
MKS Valve KF40 Shut-Off
MDC KIV-200P Valve KF50 Shut-Off
MDC KIV-150-P High Vacuum Research Chamber InLine Valve KF40 Shut-Off
Marking Burning Station Nd:Yag Optics Lambda Spectra-Physics
Fisher XT-3000
Vishay Intertechnology, Inc.将其157 PUM-SI系列超小型卡扣式功率铝电解电容的额定电压提高到500V。这些增强型器件是针对电源、工业电机控制和太阳能电池逆变器而设计的,让设计者用一个元件替代两个250V电容器,从而节省电路板空间,降低成本。
Vishay BCcomponents卡扣式电容器采用圆柱形铝外壳,用蓝色套筒绝缘,有22x 25mm~35x60mm共23种外形尺寸。在500V电压下,器件的最高工作温度为+85℃,使用寿命超过5000小时。
157 PUM-SI系列器件是使用非固态电解液的极化铝电解电容器,非常适合脉冲电源应用中的平滑、滤波和储能。电容器符合RoHS,还有键控极性的卡扣式型号。
兴锐达不吹牛!想要比同行低15个点!请贵宾来电!保证满意!
Key Valve Tech High Vacuum Research Chamber Inline Valve with KF40-KF25
High Vacuum Research Chamber ISO 100K & ISO 63F Adapter Flange K25 Varian UHV
High Vacuum K25 UHV
High Vacuum KF40 Shut-Off
Edwards FL20K Forline Inlet Trap KF25 Rotary Vane Pumps Alcatel
Fisher XT-3000
Ortec Detector Model 210" AS-IS HP
NOMOS BAT SXi Ultrasound Localization System
AEROVOX 22,000 VDC High Energy Discharge Capacitor (8) Tesla Coil AeroStor
Varian 400 ASA Vacuum Research Chamber Gate Valve MDC H.V.A.
Briskheat Percentage Mantel Controller Thermolyne Glas-Col
CVC Vacuum Research Chamber 4 Inch ASA Gate Valve MDC H.V.A.
Canon Anelva Ion Pump Control Unit PIC-060 NP
Bertan 303 High Voltage DC Nim Bin Power Supply Module 0-3000V Ortec Tennelec
MKS High KF50 Shut-Off
MKS High Vacuum Research Chamber Inline Valve KF40 Shut-Off
Fisher XT-3000
MKS High Vacuum Research Chamber 90 Degree Right Angel Valve KF50 Shut-Off MDC
联系人:刘锦燕
手机:13295922579
电话:0592-5580706
传真:0592-5361191
邮箱:LJY_05228@163.COM
QQ:2711934024
QQ:2574619415
- 电话:0592-5580706/13295922579
- 传真:0592-5361191
- email:LJY_05228@163.com
