- 型号:Indramat MDD071B-N-040-N2S-095GA1
- 数量:10
- 制造商: 厦门兴锐达自动化设备有限公司
MKS 1259B-00100SV
Burliegh Hi-Fase Fabry-Perot Etalon Interferometers Wavemeter Model HF-600-1
Whitley High Vacuum Pneumatic Ball Valve Nupro MDC
Varian Vacuum Research Chamber 6.5 ASA Elbow Flange MDC
Varian Manual Shut-Off Valve Gate Huntington MDC
Varian High Vacuum Electric Feed Through 2.75" Flange Ceramic Current MDC A&N
Thermionics High Vacuum Research Chamber Shut-Off 2.75" Flange Varian MDC
MKS Baratron Pressure Transducer 50M Torr Cluster Vac
MDC Vacuum Research 13 ¼ ”CFF Weld-On Conflat Varian Huntington
MDC High Vacuum Research 2.75" Flange Gas Chamber CFF Conflat Varian Huntington
Huntington Vacuum Research 13 ¼” CF Zero Length Reducer Varian MDC
Huntington High Vacuum Research Chamber Shut-Off CFF
Huntington High Vacuum Research 12”Flange Reducer Ring "NEW" MDC UHV Varian
Varian High Vacuum Research Chamber 2”ASA Gate Valve Cryo Trap
High Vacuum RGA Research Chamber 2 3/8"ID Residal Gas Analyzer Sid-Con Varian
Glas-Col Series O Hemispherical 100ml. Heat Mantel No. 396 Briskheat
Varian Cryo Stack 8 High Vacuum Cryogenic Pump CTI
Slo-Syn Synchronus/Stepping Motor Drive Compumotor
MDC High Vacuum Research Feed Through UHV 6"CFF Conflat Flange Varian
ITT Electronic Tube KU-247B Thyratron Excimer Spectra-Physics Quatin
AMAT Applied Material RF Source Semiconductor Wafering
Airco-Temescal Turbo Molecular Pump 514 Varian Edwards
OFweek工控网讯:最近有关苹果大尺寸iPad平板电脑的传言很多。据Apple Insider网站报道,来自亚洲的传言称,苹果已经选择夏普和富士康为多至500万台“iPad Pro”生产、装配触控模块。
据传闻夏普将负责制造显示屏,富士康负责触控模块的制造和装配等。据中国台湾地区科技网站Digitimes称,iPad Pro批量生产将从秋季开始,年底前出货量将达到400万-500万台。
有关iPad Pro的信息不多,不过业内人士一致认为,它将配置12.9英寸高分辨率显示屏,以及能实现更精确控制的触控笔。凯基证券分析师郭明池(Ming-Chi Kuo,音译)本周早些时候预测,触控笔带有自己版本的Force Touch,为iPad Pro提供压敏输入技术。
Apple Insider表示,一款据信是iPad Pro的设备还现身商业性应用分析数据中。这款设备的型号为尚未见到过的“iPad6,8”,配置分辨率为2048 X 2732像素的显示屏,iPad Air 2显示屏分辨率为2048 X 1536像素显示屏。
另据Ubergizmo网站报道,DigiTimes刊文称,夏普和富士康旗下GIS将是iPad Pro显示技术的主要供应商,三星和宸鸿科技等公司将是次要供应商,其中三星提供液晶面板装配,宸鸿科技负责触控模块。
苹果可能在9月9日举办的发布会上发布下一代iPhone,不过目前尚不清楚届时苹果是否会发布新款iPad。传统上苹果10月份发布新款平板电脑,如果iPad Pro已为发布准备就绪,苹果今年可能延续以往的传统。
新一代高级智能传感器将成为工业自动化的心脏。“智能工厂”是指在数字化工厂的基础上,利用物联网的技术和设备监控技术加强信息管理和服务,清楚掌握产销流程、提高生产过程的可控性、减少生产线上人工的干预、即时正确地采集生产线数据,以及合理的生产计画编排与生产进度。智能工厂可实现的技术包括无线感测、控制系统网路化和工业通信无线化等称重传感器。对某些产品质量指标(例如,黏度、硬度、表面光洁度、成分、颜色及味道等)进行快速直接测量并在线控制。而融合智能技术的传感器将可以很好的解决上述问题。
传感器应用非常广泛,工业生产各个组成环节都需要传感器进行监控,并把数据反馈给控制中心,以便对出现异常节点进行及时干预,保证工业生产正常进行。
业界普遍认为,工业自动化的心脏是新一代高级智能传感器,它让产品生产线持续运行,通过低延迟和实时网络,连接至高性能可编程逻辑控制器(PLC)以及人机界面(HMI)系统。当然,对制造厂商而言,时间就是金钱。只要制造的产品能够达到规定质量水平,的生产线就会尽可能快地持续运行,智能传感器重要性凸显。
目前,智能传感器作为21世纪最具影响力和发展前景高新技术,正引起国内外电子信息界的高度重视。光电行业开发协会(OIDA)预测,智能传感器的国际市场销售量将以每年20%的高速度增长,智能传感器将在工业自动化时代扮演更加重要角色。
物联网技术给工业自动化带来的变化,目前,工业生产的确在大规模向自动化方向转变,但随着物联网及云平台应用的不断投放商用化,工业领域的自动化发展有向更高层次升级的趋势,即智能化生产。
进入首页浏览更多精彩内容:
电信“互联网+”助力中国制造
2015中国机器人在线展举办中
为什么德国和日本对工业4.0 不“狂热”
兴锐达不吹牛!想要比同行低15个点!请贵宾来电!保证满意!
Varian High Voltage Cold Cathode Vacuum Gauge Model 524-2 Pfeiffer
High Vacuum Research Chamber ISO NW100 Adaptor to KF50 Varian MDC HPS
GCA McPherson Monochromator Filter Attachment EU700 ISA
Gas Cell Hi Vac Research Absorption Chamber Varian MDC
EG&G Ortec 426 Linear Gate Module Canberra Tennelec Stanford Reseach
Vacuum Generators Civ Unit KF25 Varian Peiffer
UFI SCL BioLog Model 3992/1 Animal Data LCD Screen
High Vacuum Research Chamber 13 1/4" CFF Conflat Blank Varian MDC
MDC High Vacuum Chamber 13.25" CFF Conflat Reducer Ring Huntington Varian
Edwards iQDP80/QDP80 High Vacuum ISO Flange 100-400N KF25 Varian
A&N High Vacuum Pneumatic Actuator Model 1539-S-N Whitley
MDC High Vacuum Research Chamber InLine Valve KF50 Shut-Off Varian
MDC High Vacuum Research Chamber 4.5" CFF Conflat Blank Varian Huntington
MDC High Vacuum Research Chamber 4.5" Del Seal BlankFlange Huntington Varian A&N
iQDP80/QDP80 High Vacuum ISO63/ISO100 Flang Edwards Varian
iQDP80/QDP80 High Vacuum Edwards ISO63/ISO100 Flang Varian Pheiffer
Huntington High Vacuum Research Chamber 8" CFF Conflat Blank Varian
Huntington High Vacuum Reasearch Chamber 8" Flange Conflat MDC Pfeiffer Varian
High Vacuum Chamber 200ASA Vacuum Fittings Varian MDC
Pressure Transducer Vacuum Gauge 521A-5 " " Baratron 1K
Pressure Transducer Vacuum Gauge 503L " " Baratron 1K
联系人:刘锦燕
手机:13295922579
电话:0592-5580706
传真:0592-5361191
邮箱:LJY_05228@163.COM
QQ:2711934024
QQ:2574619415
- 电话:0592-5580706/13295922579
- 传真:0592-5361191
- email:LJY_05228@163.com
