- 型号:KLA-Tencor 0095643-000
- 数量:10
- 制造商: 厦门兴锐达自动化设备有限公司
TEL Tokyo Electron ES Shield Depo 85-WR DRM2 1D10-311227-W1 new
Leybold-Heraeus WS-152 Vacuum Pump Assembly DK-50 Not
Leybold-Heraeus WS-152 Vacuum Pump Assembly Not As-Is
Leybold-Heraeus WS-152 Vacuum Pump Assembly DK-50 As-Is
Ebara ET300W Type 1 Vacuum Turbopump not
Kikusui PMC18-2A DC Power Supply SUNX SF1-SC TEL Unity II
SVG ASML 859-8341-004-F Exposure Lamp Power Supply HC40-C1097
Robitech 980-2300 Valve Module 681-0181-009 Lot of 7
Valcom Pressure Switch RN-760Torr-2VAO-4TL7 Lot of 9
LAM Research I/O Breakout Board 810-17002-001 Rev. D
Emoteq Brushless Servo Motor HT05002-C01-HBE Lot of (5)
MRC 883-37-000 I/O Receiver Control Board Rev.B A110999
Semitool Ceradyne 950T0006-01 300mm Film Heater Thermal Chamber Substrate new
Saint-Gobain Furon VPM3-F46 Regulator Valve New
Parker Elbow Connector FEC-6-P-T Lot of 46 New
AMAT Applied Materials 0100-09174 Gas Interface Board TEOS P5000
DIP CDN396 Bi-Directional Digital I/O PCB Card 15039603 New Surplus
PI Physik Instrumente 780-08568-000 Piezo Controller P-265
Lam Research Blank Cover 713-21816-1 Rev.B
TEL Tokyo Electron 208-500283-3 External RAM Board
Intraplex Inc. 9547-1827-1 Data Module DS-965/DA-191A Rev. AC New
Blazers Signal Interface Board BG442310-T/F
Siemens Analog Output Module 6ES7 432-IHF00-0AB0
Product Systems MicroPulse Controller
Applied Materials AMAT 0200-30073 Ring Assembly New
Prometriz Corp. 36-0276 Door Interconnect Board Rev.A
Hepa (9.125)(22.5)22.5EIIDG7.5E-S Hepa-Pleat II Filter new
TEL Tokyo Electron HTE-PUM-A-11 Pump Add on Board CPC-0229A01B-11
Blacoh H3120TF-TC Pulsation Dampener new
Pall T7100080300 Housing Filter CMP Capsule lot of 14 T46141-36 new Semitool
AMAT 0100-90870 Rev. D 4 Phase Stepper Controller Board XR80
TEL Tokyo Electron CR-125 Full Wafer Holder Housing D127110 Rev.B new
Saes Getters UHP504C606-10 In-Line Manual Valve Lot of 4
Siemens 6ES7 432-IHF00-0AB0 Analog Output Module OEM Boxed
Yaskawa Linear Motor Controller CLSR-A504-N2SB Nikon
Parker Laser Stage Positioning System Model 4082
WS系列蝶阀 Pawkywonne生产的蝶阀应用范围广泛,性能稳定 WF系列调节阀 Pawkywonne生产的调节阀压降损失小、流量大、可调范围广,流量特性曲线精度高,阀芯导向面积大、抗振性好。 WV系列球阀 Pawkywonne生产的球阀具有独特的特点。 OVP系列电动执行机构 PAWKYWONNE公司在1996年开始筹备研发速度和精度可与气动相媲美的高性能电动执行机构;在传统电动执行机构经验和积累的基础上,2001年OVP系列高性能电动执行机构成功投入批量生产。 EMT系列智能型电动执行机构 EMT系列电动执行机构采用图形点阵式液晶显示器,以字母或中文、数字、图形等形式显示执行机构的转矩、阀门开度、限位设定等工作状态和报警。该执行机构具有自动保护功能和自诊断功能,由于具有隔爆功能,即使在危险区域也无需打开正在工作中的执行机构电气箱盖就可以进行调节、参数检查、故障诊断。采用现场总线通讯卡,可以构成全分布式计算机协同工作系统,实现远程数据采集、远程通讯和远程诊断与维护。由于它的先进性、可靠性和操作方便等特点,在油田、电力、冶金、水处理、造纸、化工等行业中得到广泛应用,深受广大用户的欢迎。 RDK系列角行程气动执行机构 RDK系列气动执行机构在降低维护需求的同时,可为角行程阀门的操作提供稳定可靠的动力。双齿条和齿轮设计提供了可靠的扭矩输出和有效性能。利用PAWKYWONNE公司在试验和运行中取得的经验,结合最新技术创新,RDK系列执行机构具备高品质、可靠性和经济性的优点。 RDH系列角行程大扭矩气动执行机构 PAWKYWONNE生产的RDH系列产品可根据阀门的使用要求提供对称式或非对称式扭矩输出的气动执行机,缸内配有可更换轴承,并在内部涂有高性能抗磨损和腐蚀的涂料。RDH系列气动执行机构在质量控制系统控制下进行生产和装配,我们向客户提供可靠的,高质量的产品。 ZSL系列直行程气动执行机构 该系列气动执行机构的缸径Ф32~Ф320,有气动执行机构两端带缓冲和不带缓冲的两种规格,均符合IS06431标准,两种气动执行机构的外形尺寸、安装方式完全相同。
兴锐达不吹牛!想要比同行低15个点!请贵宾来电!保证满意!
Hine Design 04290-201 Process Chamber Elevator Gasonics 94-1118
Tokyo Electron ES Cover Bellows A DRM2 1D10-200734-W1 new
ASML Stepper UVHR 3 In. Mirror 8541806001
Inficon HPR-1100 Transpector Residual Gas Analyzer Assembly
Heatcraft 88710201 BOHN Outdoor Dual Fan Evaporative Cooler
Applied Materials AMAT 0200-09084 Quartz Shield 125MM New
Varian E17332311 Beamgate Side Liner Rev.A lot of 26 new
Hitachi 3-841437 SMC Air Cylinder CDQ2B40-01-59469 Qty3
Pfeiffer Balzers PM-C01-502 Pump Station Control Unit TCS-303 Lot of 5 As-Is
Medtronic 1718A012 Y4 Surger Control MIE586 Temperature Chamber
Oerlikon USA Unaxis Fixload Control PCB 102105235 New
Sieger Limited 05700-A-0652 Gas Detection Module RAD-10
SVG 99-39988-01 90S Sensor Board Assembly Rev.K 99-80207-02 99-80315-01
Power-One MAP110-4200C Power Supplies Lot of Two
LAM Research 853-001983-010 Endpoint Detector 4420 Rev. T
SVG 90S Sensor Board Assembly 99-80207-02 Rev. E 99-80315-01
SVG Shuttle Interface Board 99-80269-01 Rev.G
SVG Shuttle Interface Board 99-80269-01 Rev.J
Cosel K25A-12-N Power Supply P15E-15-N K25A-12 Lot of 24
- 电话:0592-5580706/13295922579
- 传真:0592-5361191
- email:LJY_05228@163.com
工控宝APP下载安装
