- 型号:Omron 3286-002066-11
- 数量:10
- 制造商: 厦门兴锐达自动化设备有限公司
Omron TEL P8 Interface Board NO000 3286-002065-11
MKS Mass Spectrometer Filament Head LM506-03059-1F1
Millipore CMHT-11S02 Manometer Lam 4420 853-011054-503-1-LEAN
Nikon NSR S306C RST-ADPT PCB 4S019-083
ASML 4022-471-5658 VME Control Board
ASML Nikon NSR S307E Monitor PCB 4022.471.6909
Xyplex 16 Port Terminal Server Card 500-5734
Horner Electronic CPU Module HE610DPC164A Lot of 2
Teledyne Harmonic Filter Board 1002363800 Rev. B
CFM Technologies Power Box A30-00210
Omron Kokusai Vertron DD803V Flange Temperature Controller E5CS Lot of 2
Motoyama 2 Way 1/4-inch VCR F/F Manual Valve SUSF316L lot of 12
Tokyo Electron TEL Prealigner Lamp Module Unity 2 Lot of 2
Material Support Resources KF80 Kokusai Vertron DD803V Bellows Lot of 3 New
Material Support Resources Inner Tube Support 0107121-302 New
Material Support Resources Flange Seal 0107121-416 New
Applied Materials AMAT Chamber I/O Display 0130-00525 Rev. 003
DNS Electronics Sensor Module DS-1211-ANALOG(C) PU3-PCB(KG) SCREEN MC-701
Fujikin Valve Top Works 021367 021369 Lot of 14
Applied Materials AMAT Chamber Exhaust Liner 0020-64708 New
Applied Materials AMAT 3/8" OD Backside Gasline 300mm 0050-54972 New
AMAT Applied Materials 0270-04401 Endura 2 Turbo Shimadzu Support new
AMAT Applied Materials 0242-10662 ESC Blankoff for CCM Kit new
AMAT Applied Materials 0242-41460 AFEOL Foreline Elbow Assembly Kit New
AMAT Applied Materials 0242-26906 M/F NO Chamber Position Kit new
Applied Materials AMAT CHM Return Line 300mm 0050-96206 New
Applied Materials AMAT Feed Thru Tube Precursor 0021-76671 New
AMAT Applied Materials 0240-A9470 End Effector ITU Field Upgrade Kit New Surplus
AMAT Applied Materials 0240-14675 Argon Gasline 300mm PVD Kit new
Nikon 4S018-384 PCB Board
Nikon 4S018-354 AIRCTRL3 PCB Board
Nikon 4S015-119 NK386SX4 PCB Board
Nikon 4S018-608 WL3I06 PCB Board
Nikon 4S018-351 PCB Board OPDCTRL2
Nikon Power Supply 4S001-068 PCB Board
Nikon 4S015-096 NK-C303-40 PCB Board
Nikon 4S018-591 LMDRVX2A PCB Board
Nikon 4S018-382 RSMDRVX2 PCB Board
Nikon 4S018-445 EPDRV2-X2A PCB Board
Nikon 4S018-383 RSSDRVX2 PCB Board
Nikon 4S018-444-EPDRV1-X2A PCB Board
产品名称: PLC
产品型号: FX1S-14MT-001
产品价格: 360元
基本参数: 输出6
产品介绍:
● 控制规模:14MR/MT
● 内置2K容量的EEPROM存储器,无需电池,免维护
● CPU运算处理速度0.55~0.7μS/基本指令
● 基本单元内置2轴独立最高100kHz定位功能(晶体管输出型)
● 简单介绍
● FX1S系列PLC把优良的特点都融合进一个很小的控制器中。
● FX1S-14MR/MT适用于最小的封装,提供14个I/O,并且能通过串行通信传输数据,所以它能用在紧凑型PLC不能
● 输入输出点数:
输入输出合计点数 输入点数 输出点数 DC输入 继电器输出 DC输入 晶体管输出
10 6 4 FX1s-10MR-001 FX1s-10MT-001
14 8 6 FX1s-14MR-001 FX1s-14MT-001
20 12 8 FX1s-20MR-001 FX1s-20MT-001
30 16 14 FX1s-30MR-001 FX1s-30MT-001
●其它功能
内置式24V直流电源 24V、400mA直流电源可用于外围设备,如传感器或其它元件。
时钟功能和小时表功能 在所有的FX1sPLC中都有实时时钟标准。时间设置和比较指令易于操作。小时表功能对过程跟踪和机器维护提供了有价值的信息。
持续扫描功能 为应用所需求的持续扫描时间定义操作周期。
输入滤波器调节功能 可以用输入滤波器平整输入信号(在基本单元中x000到x017)。
元件注解记录功能 元件注解可以记录在程序寄存器中。
在线程序编辑 在线改变程序不会损失工作时间或停止生产运转。
RUN/STOP 开关 面板上运行/停止开关易于操作。
远程维护 远处的编程软件可以通过调制解调器通信来监测、上载或卸载程序和数据
密码保护 使用一个八位数字密码保护您的程序。
●交流电源、24V直流输入类型
模型 I/O总数 输入 输出 尺寸
mm(英寸)
(宽)*(厚)*(高)
数目 类型 数目 类型
FX1s-14MR-001 14 8 漏型 6 继电器 60*75*90
(2.4*3.0*3.5)
FX1s-14MT 晶体管
兴锐达不吹牛!想要比同行低15个点!请贵宾来电!保证满意!
Nikon 4S018-548 SR-EXT170 Extension Board
Daifuku Teaching Box B255M
Nikon 4022.470.0883 Power Supply PCB Board
Nikon 4S001-060 Power Supply PW-NA PCB Board
Nikon Power Amplifier 4S008-050 MIS-POWAMPX4 PCB Board
Nikon 4S013-510 SPAIFX4B PCB Board
Nikon 4S018-716 OPDCTRL3 PCB Board
Nikon 4S018-885 CPCI IP PCB Board NSR S307E
Jikco 4S587-736-1 Monitor Box Nikon COX-B7A
Agilent Z4381A Phase Detector PCB Board
Jikco Nikon 4S588-280 Channel Box COX-10D
Nikon 4S001-107 Power Supply VDBC0002201
Lam Research 810-17018-002 Gap Motor Controller BD PCB Rev. H Rainbow 4420
KLA-Tencor CRS 2000 Mirror Assembly
Nikon NSR Series WL3MTR-H6 PCB 4S018-531-1
Nikon NSR Series X4-AIS PCB 4S008-052-C A-554
ASML 4022.635.81433 2-Way Manifold FNPT 2 1/2-2X NUT DN50 New
Novellus 03-034720-00N DLCM-S Right Loadlock Interface PCB Rev. C
Bio-Rad Y5304400 Real Time Stage Reader Quaestor Q7
KoMiCo S31A-GD-010-A GDP 1.0mm Plate 500080005
AMAT Applied Materials 0100-35273 TEOS Temperature Con
联系人:刘锦燕
手机:13295922579
电话:0592-5580706
传真:0592-5361191
邮箱:LJY_05228@163.COM
QQ:2711934024
QQ:2574619415
- 电话:0592-5580706/13295922579
- 传真:0592-5361191
- email:LJY_05228@163.com
工控宝APP下载安装
