- 型号:Brooks SLA7950D1EGG1A2A1
- 数量:10
- 制造商: 厦门兴锐达自动化设备有限公司
Brooks Instrument SLA7950D1EGG1A2A1 Mass Flow Controller 30 SCCM
Celerity UFM-8100 Mass Flow Controller 50 SCCM N2
Pro-Face GP4TIR-EG41-24VP Touch Screen Graphic Panel 2780027-01
Edwards SDT Gas Block (KROM) Manifold VAS1-0/10R/NQ DG17VCT8-SWG New
ONEAC 012-007 Power Conditioner CC1128
Lam Research 853-012350-002-F-230S Outer Gate Assembly Un
Lam Research 853-012350-002-H-DFT Outer Gate Assembly Un
TMP Shimadzu TMP-203M Turbo Molecular Pump Not As-Is
KLK Inc A-10 Ergo Flipper Right and Left Lot of 3 As-Is
Varian E1928510 Water Filteration Assembly Un As-Is
Haskris Company R050 Recirculating Chiller R-Series Not As-Is
Haskris Company MW1 Recirculating Chiller As-Is
Kensington Laboratories 77-4000-6107-00 Arm Axis PCB Card 36-4823-0017-02
Animatics SM1720M Smart Motor Ver. 4.15b SA-4-A.083-AB-2-K-1/4-KNOB
Acran 5SFT1313 Safefloor Safety Aisle Mat Lot of 144 New
VAT 03009-NA24-1004 Slit Valve Novellus Concept II Altus
VAT 03009-NA24-1001 Slit Valve Novellus Concept II Altus
VAT 03109-NA24-AJX1 Slit Valve Novellus 02-115278-00N Concept II Altus
VAT 61144-PA52-1008 Throttle Valve
Kensington Laboratories 77-4000-6107-00 Waist Axis PCB Card 3-0018-01
Kensington Laboratories 77-4000-6108-00 Z Axis Robot PCB 7-0003-02 v10.45
AMAT Applied Materials 0100-90710 Vacuum Gauge Interface Board Rev.D
Novellus 03-034719-00N DLCM-S Left Loadlock Interface PCB Rev. A
Granville-Phillips 275821 Differential Output Amplifier Series 275 lot of 5
MRC Materials Research Corp 883•87-00 PCB Board Eclipse Star
Noah Precision SVG 90S Fluid Temperature Bath 2005 Rev. D
产品名称: PLC
产品型号: FX1S-14MT-001
产品价格: 360元
基本参数: 输出6
产品介绍:
● 控制规模:14MR/MT
● 内置2K容量的EEPROM存储器,无需电池,免维护
● CPU运算处理速度0.55~0.7μS/基本指令
● 基本单元内置2轴独立最高100kHz定位功能(晶体管输出型)
● 简单介绍
● FX1S系列PLC把优良的特点都融合进一个很小的控制器中。
● FX1S-14MR/MT适用于最小的封装,提供14个I/O,并且能通过串行通信传输数据,所以它能用在紧凑型PLC不能
● 输入输出点数:
输入输出合计点数 输入点数 输出点数 DC输入 继电器输出 DC输入 晶体管输出
10 6 4 FX1s-10MR-001 FX1s-10MT-001
14 8 6 FX1s-14MR-001 FX1s-14MT-001
20 12 8 FX1s-20MR-001 FX1s-20MT-001
30 16 14 FX1s-30MR-001 FX1s-30MT-001
●其它功能
内置式24V直流电源 24V、400mA直流电源可用于外围设备,如传感器或其它元件。
时钟功能和小时表功能 在所有的FX1sPLC中都有实时时钟标准。时间设置和比较指令易于操作。小时表功能对过程跟踪和机器维护提供了有价值的信息。
持续扫描功能 为应用所需求的持续扫描时间定义操作周期。
输入滤波器调节功能 可以用输入滤波器平整输入信号(在基本单元中x000到x017)。
元件注解记录功能 元件注解可以记录在程序寄存器中。
在线程序编辑 在线改变程序不会损失工作时间或停止生产运转。
RUN/STOP 开关 面板上运行/停止开关易于操作。
远程维护 远处的编程软件可以通过调制解调器通信来监测、上载或卸载程序和数据
密码保护 使用一个八位数字密码保护您的程序。
●交流电源、24V直流输入类型
模型 I/O总数 输入 输出 尺寸
mm(英寸)
(宽)*(厚)*(高)
数目 类型 数目 类型
FX1s-14MR-001 14 8 漏型 6 继电器 60*75*90
(2.4*3.0*3.5)
FX1s-14MT 晶体管
兴锐达不吹牛!想要比同行低15个点!请贵宾来电!保证满意!
Edwards A52844413 im Pump Interface Flash Module
Kokusai VDF Vertron Exhaust Monitor D12549
Square D Vertron Circuit Breaker KAL262001127 Lot of 4
Dalsa TA-L2-04K30-50E Lens Module Hitachi I-900SRT Lot of 2 As-Is
Nemic-Lambda EWS50-12 NNS50-15 EWS300-5 DC Power Supply Lot of 5
Anelva H13-1798 Photocoupler Module
SUNX SC-MIL SC-T8J FX-301B FT-WA8 Photoelectric Sensor Modules Lot of 4
Siemens Simatic Analog Input 6ES5 464-8ME11
Siemens Simatic Analog Output 6ES5 470-8MA12
Chemetal Anelva PVD Ring Shield Holder 233-3057-99 new
Pentagon Tech. Anelva PVD Door Shield 233-3055-12 new
Pentagon Tech. Anelva PVD Door Shield 233-3050-80 new
MRC Material Research Corp A118030 Cyropump Temperature Monitor Eclipse
Daikin DFS410TC1B Fan Filter Unit MMH4601000 TEL Tokyo Electron Lithius FFU
Therma-Wave 18-010747 DC Chopper Monitor 14-006552 Opti-Probe 2600B
联系人:刘锦燕
手机:13295922579
电话:0592-5580706
传真:0592-5361191
邮箱:LJY_05228@163.COM
QQ:2711934024
QQ:2574619415
- 电话:0592-5580706/13295922579
- 传真:0592-5361191
- email:LJY_05228@163.com
