![](http://nfs.gongkong.com/Upload/trade/201512/20151210141202964_w.jpg)
- 型号:Genmark HBP14SD
- 数量:10
- 制造商: 厦门兴锐达自动化设备有限公司
Yaskawa SGD-01AN Servopack Servo Amplifier
TEL Tokyo Electron 1D81-000120 PCB Board TYB419-1/PC Unity II Missing Tabs
Electroglas PEAK/DM-386DX Processor Motherboard PCB
Robitech 858-8164-001 Reticle Handling Robitech Interface PCB Card
Electroglas 114824-002 28V Solenoid Drivers PCB Card Rev. B
Fusion Systems 248411 8086 CPU Card PCB Rev. B
Lambda LFS-45A-24 Regulated Power Supply Un
Genmark HBP14SD
Aera TC FC-D985CT-BH Mass Flow Controller FC-D985c 300 CCM CI2(0.856)
UNIT UFC-1660 Mass Flow Controller 1660 Metal Z-Seal 3.5 SLM He
Cole-Parmer 7553-30 Masterflex Pump Motor with Double Head
MDC KAV-150-P Pneumatic Angle Valve Lot of 2
Maxon 44.025.000-00.09-084 DC Motor Swiss Made
Aera FC-785CL Mass Flow Controller FC-785C 1000 SCCM AR
STEC SEC-7350M Mass Flow Controller 15 SLM He
Vacuum General FS6-31 Mass Flow Controller 0-1000 SCCM
ABB 60-2310-042 Pole Circuit Breaker 125A New
Lintec LM-1100M-8 Liquid Flow Controller TEOS 0.1g/min
Yaskawa UTOPI-020MX Minertia Motor RM Series
Genmark HBP14SD
接口特性:接口兼容EIA/TIA的RS232.RS485/422标准
电气接口:RS232端DB9孔型连接器,RS485/422端6位接线柱连接器,支持128节点,+/-15KV防静电,配接线柱,支持128节点,
保护等级:RS485.RS422接口 每线600W的雷击浪涌保护;+/-15KV防静电。
隔离度:隔离电压2500Vrms 500DC连续, 电源全隔离
工作方式:异步半双工,全双工差分传输自动选择,无需跳线设置
传输介质:双绞线或屏蔽线
7.传输速率:300BPS-115.2KBPS
8.外形尺寸:80mm×33mm×19mm
9.使用环境:军工级-40℃到85℃,工业级0-80℃; 相对温度为5%到95%
10.传输距离:0-1800米(RS485/422端) )(115200BPS-9600BPS)
11.信号指示:一个信号指示灯电源(PWR)
12.电源:220VAC输入隔离5VDC输出;直流12V、24V、48V、110V。
兴锐达不吹牛!想要比同行低15个点!请贵宾来电!保证满意!
Tylan DFC-2952MEP5-T 2950 Series Mass Flow Controller 250 SCCM CO
Tylan FC-280V Mass Flow Controller FC-280 100 sccm H2
Aera FC-D985CT-BH Mass Flow Controller FC-D985c 300 SCCM CI2(0.837)
STEC SEC-4550M Mass Flow Controller 50 SLM H2
STEC SEC-4550M Mass Flow Controller 30 SLM HCl
STEC SEC-4400M Mass Flow Controller 200 SCCM SiH2Cl2
STEC SEC-4500M Mass Flow Controller 20 SLM H2
STEC SEC-4500M Mass Flow Controller 10 SLM He
STEC SEC-4400M Mass Flow Controller 500 SCCM SiH4
STEC SEC-4400M Mass Flow Controller 500 SCCM HCl
Edwards D14641800 Active Gauge EXT-AIM-S
Square D 316-2121-003 Analog Motherboard Seriplex AMAT 0660-01506
MKS Instruments 421 Cold Cathode Gauge Micro-Controller HPS
Sierra Instruments 824S-RFQ-2297 Mass Flow Meter 0-100 NLPH
Nikon FIAAF-TYUUKEI-H NSR Scanner PCB 4S007-931
Genmark HBP14SD
Nikon FIAAF-TYUUKEI-A NSR Scanner PCB 4S007-948
Nor-Cal 090409-22 In-Line Pneumatic Valve
Aera FC-D985CT-BH Mass Flow Controller FC-D985c 400 SCCM NF3(0.479)
Edwards D37215000 Vacuum Flash Module Lot of 2
Oriental Motor UDX5107N 5-Phase Stepping Motor Amplifier Super Vexta
Tylan 2950 Series MFC Lot FC-2950MEP5-4V un
Siemens Simatic Digital Output 6ES5 453-8MA11
Fujikin MFC Mass Flow Controller FCS-4WS-798 Lot of 5
Edwards A53231000 Booster Connection Kit iQDP40 iQMB250F New
Genmark HBP14SD
MKS 683B-29016 Type 683 Control Valve
联系人:刘锦燕
手机:13295922579
电话:0592-5580706
传真:0592-5361191
邮箱:LJY_05228@163.COM
QQ:2711934024
QQ:2574619415
- 电话:0592-5580706/13295922579
- 传真:0592-5361191
- email:LJY_05228@163.com
