- 型号: 0039463 - FOXBORO
- 数量:18
- 制造商:深圳长欣自动化设备有限公司
- 有效期:2020/12/11 0:00:00
超低价热卖热卖, 降价风暴降价风暴 , 进口现货,诚信经销 专业供应?Allen Bradley 应有尽有 , Allen Bradley超低优惠价 , 独家折扣?再度劲爆价
AMAT XR80 Implanter Control Interface 9090-00101 ITL
AMAT XR80 Implanter Vacuum Controller 0090-91927 ITL
AMAT XR80 Implanter Cryopump Controller 9090-00246 ITL
Edwards Vacuum Pump QDP80 Blower QMB250
Novellus 02-145733-00N C Heater Pedestal Untested as-is
Novellus 02-282782-00 A Heater Pedestal Untested as-is
Novellus 02-287782-00 A Heater Pedestal Untested as-is
MKS 31587 14 Cold Trap Assembly Watercooled
Berkeley Process Control BX2-8/6-01-A BX2 Controller AMAT 0500-00282
VAT 0340X-CA24-BMB1 Rectangular Insert MONOVAT Direct AMAT 3870-05061
Olympus BH3-5NR3-M Microscope Assembly BH2-HLSH KLA-Tencor CRS1010S
Asyst 6331/27273 Handler
Novellus 02-258524-00N A Heater Pedestal Untested as-is
Shimadzu EI-D3403MT Turbopump Controller 262-78797-02 0190-19088
AMAT Applied Materials 0010-13321 8" Robot P5000 Untested As-Is Precision 5000
Lam 4420 Reaction & Lower Chamber 852-011061-503 Lower Match Box 853-015000-002
CT TEL Tokyo Electron 851 ACT 12 300mm WEE Edge Exposure CT2986-405695-W1 as-is
KLA-Tencor AIT1 Olympus Microscope Assembly
TMC Technical Manufacturing Corp KLA-Tencor STACIS 2000 Active Vibration Control
KLA-Tencor AIT2 Heat Exhaust Blower 570-0443
TEL ACT 12 WEE X-Theta Drive Assy 200mm
Ebara ET600WS Turbo-Molecular Pump VG150 Flange locked rotor untested as-is
Ebara ET300WS Turbo-Molecular Pump AET08-1018 needs rebuild as-is
Robitech 859-8067-004 Pneumatic Pressure Console Rev. A 990-9160
Robitech 859-8067-002 Pneumatic Pressure Console
Robitech 859-8067-003 Pneumatic Pressure Console Rev. A
Therma-Wave TP-420 Laser Power Supply 208V 20A Single Phase
Comdel CPS-500AS 13.56MHz RF Power Source FP0113RK 0920-01056
port Beam Height Gauge 8035-0082 Rev. D
Semiquip AMAT Centura Endura 200mm Cassette Alignment Tool LCAT200P-20001
Arista Panel Interface Computer ARP-2610AP 667MHz
Yaskawa Transfer Robot Track XU-ACL4720
KLA-Tencor Retrofit Optics Beamsplitter 0099602-001
KLA-Tencor SLX Objective Lens 760-334096-000 Untested
Daikin 3D80-000709-V4 Brine Chilling Unit ACRO UBRP4CTLIN Untested As-Is
AMAT Applied Materials 7323 75kVA XFMR Quality Transformer 0190-06937
AMAT Applied Materials 0270-05868 Neon Chamber Lower Liner Removal Fixture
Motorola WiMAX WAP Access Point STHX4006DA 2.3GHz XCVR Assy.
Applied Materials AMAT 0020-30628 Vespel Clamp Ring
Semitool Bimba Air Cylinder D-69457-A Lot of 14
Nikon NSR-S307E Linear Track Z-4B1A-A1601
Johnson Matthey Copper Target Plate S12460-E
Dynatronix PMC10-1-3/20-60 PR Pulse Power Supply PMC102/1PR-1-3/1PR-20-60
Yaskawa Transfer Robot Linear Track XU-ACL4141
Anatech Carbon Deposition System CDS 2.2 untested
Nikon Z-A65635 NSR S202 Scanner 200mm Indexer
ENI Polara-260A Bipolar Pulsed Supply Surplus 0190-01428
Berkeley Process 300mm Prealigner 100-000-871-02 9010-01808
Nikon NSR-S202A 200mm Wafer Handler Prealigner
KLA-Tencor Cannon Box Magazine Assembly 740-060658-001
Semitool 200mm 50 Wafer Carrierless Rotor Assembly 500R0333-01 refurbished
Semitool 500R0409-01 50 Wafer Carrierless Rotor Assembly 200mm refurbished
VAT 0750X-UE24-ACU1 Double Actuator Slit Valve 3870-00427
ENI OEM-12A Solid State RF Power Generator OEM-12A-21041-51 Rev.G
Nikon Optistation OST-3\3A LED-AF Microscope Head 81027
Edwards NRY12J000 iGX6 Vacuum System Frame And Accessories Surplus
Edwards NRY1ML000 iGX6 Vacuum System Frame And Accessories Surplus
Edwards NRY0P8000A iGX6 Vacuum System Frame And Accessories Surplus
Comdel CX-200S V-Quad RF Generator CXV-200
AMAT XR80 Micro Discharge Sense Box X2HA 0090-91422
Hitachi M-308ATE PCB Cage System Controller Module
port Kensington 300mm Wafer Robot 15-3701-1425-25
Grundfus Multistage Centrifugal Pump CR5-2-A-A-A-E-HQQE
Ebara ET300WS-A Vacuum Turbopump AET08-1016 Not
Seiko Seiki Turbopump Controller SCU-H2001K2
port Kensington 300mm Transfer Robot 35-3700-1425-18 Refurbished 0190-10829
Stearns MRC Eclipse Star Drive Assembly 2-12-1807-00-AEH
Cisco 7507 7500 Series Router Switch W/Blades 7 Slots
Siemens Closed Loop Controller 6ES5 262-8MA12
Yaskawa 300mm Prealigner XU-ACP130-B11
port Kensington Robot 15-3701-1425-25 0190-19124
AMAT XR80 Implanter Controller 0090-91404 ITL
AMAT XR80 Implanter Controller 9090-00098 ITL
Luxtron 100C M-100 Optical Fiber Temperature Control System 0190-35236
SVG 90S Fixture Parts Lot B W/ 23-42973-01 And More
Hitachi ER Cover, UHF, 2-832793-01
ENI OEM-650A Solid State Power Generator OEM-6A-11491-51 Rev.G
AMAT XR80 Power Distribution Unit 9090-00511 ITL
AMAT XR80 Power Distribution Unit 9090-00194 ITL
Rasco WTC-D188-ANL(RI) Dual Channel Recirculating Chiller As-Is
Delta Design 9023 Environmental Test Chamber Tested
Vicor PFC MEGAPAC Power Supply MPG-77532 1140-00310
AMAT Applied Materials 9090-00742ITL Beamline Monitoring Module Rev. B
Varian E11104160 On Board Cryo Purge Controller
Varian E11098300 On Board Cryo Purge Controller Rev. D
Varian E11086971 Signal Tower Controller Rev. D
Yaskawa SGDB-44ADG Servo Drive Servopack
Motorola VME162PA-252SE Embedded Controller
HP Hewlett-Packard 4085B Switching Matrix Controller As-Is
Aera FC-PA7810c H2N2 20SLM 22-324850-00 MFC Mass Flow Controller lot of 3
SVG Pacific Scientific SC755A040-08 Spindle Controller with some damage
Tencor 33205 AC Power Box Assembly LPM
Tencor 332305 AC Power Box Assembly LPM
AMAT Applied Materials 9090-00742 Beamline Monitoring Module Rev. D
Hine Design Chamber Robot Assembly Gasonics Aura 2000LL 200mm
Hine Design Cassette Wafer Robot Assembly Aura 2000LL
Schlumberger IX Pin Slice Single Board 97923140 Rev. 3
TEL Tokyo Electron Cup Wash Disc ACT 12 200mm
Edwards Shutter Disk 633-5583-66 AMAT Centura 0021-17725
Schneider Electric LC1F150 Contactor 24V 50Hz Reseller Lot of 18
Ebara 306W Turbo Molecular Pump Controller AMAT 0020-14981
Nikon NSR AVIS2 ERG Amp Module 4S587-011
Yaskawa SGDH-75AE Y906 Platen Rotation Motor Driver AMAT 0190-08040
Orion ETD452-DA-UL Pel Thermo Power Supply
Innova Electronics 15" Flat Panel Monitor STS-4015-P-AM
Innova Electronics 15" Flat Panel Monitor STS-4015-PT
Federal Dimensional Gauge EAS-2350 8035-0129-000
AMAT XR80 Implant Spin Relay Controller 0090-93095 ITL
LAM Research 4420 Rear E.M.O. Enclosure 860-010168-001
HiTek Power DC Supply A1023050
KLA-Tencor AIT APS Tower/Center Block 0071149-001
Asyst SMIF-300FL Load Port 300FL,S2.1 HAMA/E-84
VAT MONOVAT Slit Valve 0340X-CI24-AVF1
VAT 0210X-BA24-AXN1 Transfer Valve MONOVAT surplus
AMAT Applied Materials 0010-45533 LDM Megasonic Onboard Mixing Assembly
Eaton LGE3630NN Industrial Circuit Breaker ELLBN3600W AMAT 0680-02434
KLA-Tencor Lower Octopole/Wein Lens 780-14108-000 Negative Polarity with Case
KLA-Tencor 780-14108-000 Lower Octopole/Wein Positive Polarity Lens and case
Integrated Dynamics Engineering TC 800043-001
Rorze Robot Linear Track and Controller RT107-1201-002
Lot of 34 RK Industries RK-DAV-251E1 Divertor Air Valves FT492-12696-00
AMAT XR80 Implant Gap Servo Controller 0090-91251 ITL
AMAT Controller Distribution Board 0100-00523
SRC Computer Module S309163 Diafuku VME-5620, OPC-5600B
Pentagon Technologies WZ10-103558-11 X1 Large Upper Shield Sealed
Novellus Digital Dynamics SIOC Controller 02-258471-00
AMAT XR80 Implant Gap Servo Controller 9090-00097 ITL
KLA-Tencor 285293 AIT 2 GPIO Board 386065 Rev.AC
Applied Ceramics 911-02052A Chamber Insert 200MM 0200-00261
Celerity IFC-125C various Gas & Range 0190-28862 Mass Flow Controller lot of 8
MDC Lift Assembly ABLM-133-1 (KLH)
Semitool Kaijo Hi Megasonic 600 Ultrasonic Generator 69101-SE
VAT MONOVAT Rectangular Dual Slit Valve 0210X-CA24
Luxtron Xinix 1014 Endpoint Controller 5001-1014-01-00
Varian TV 70 Vacuum Turbopump 969-9368S004
Nikon Dual Board Assembly PCB 9700-5327-01
Spectra-Physics 2560-56 Laser Power Supply rebuilt
MEL Systems And Services MBT 240i MELSS Surplus
AMAT 200mm Cover Ring AL 0020-24719
Tosoh AMAT Endura Lower Shield 805-435-SG-F-258
Tosoh AMAT Endura Inner Shield 805-381-SA-F-301
TEL Eclipse Star Shield Kit 42755-0500
Millipore FC-2900M Mass Flow Controller HE 20 SCCM Tylan Lot of 8 As-Is
Millipore FSDGD100CK00 FSCGD100FC00 DeviceNet Surface Mount Lot of 18 MFC AS-IS
Nikon NSR 4S013-374-1 AVIS1 ERG Amplifier 4S587-624
Nikon NSR AVIS2 ERG Amp 4S587-011-1
Leybold TM21 TM22 Vacuum Gauge Controller Module
Kokusai Vertron Linear Track V-III-A
MRC Eclipse Star SS Relay Assembly A129350
STi OF4172B-2 OptoFence Series Light Curtain Set Lot of 2 sets
VAT Monovat Slit Valve 0750X-UE21-AAL8
AMAT Applied Materials 0090-06254 Centura ACP Remote Assembly
Semitool 330S0016-01 12-Gallon Heated Tank N014502-001
AE Advanced Energy E'Wave 3152603-014 DC Pulse Generator Rev.B as-is 0190-15526
Lambda EWS100-5 DC Power Supply lot of 15 tested
AE Advanced Energy LF-5 RF Generator 7520572050
Steag AC Power Supply 7100-7870-06
TEL P-8 KLA-Tencor P8 Bridge 740-806002-00 Rev.GA
TEL P-8 KLA-Tencor P8 Bridge 740-806002-00 Rev.FB2
AMAT Applied Materials 8310 Hexode Assembly 100mm
Applied Materials AMAT 0010-09574 Pedestal 125MM Flat
Semitool 330S0017-01SEP 12 Gallon Heated Tank Assembly refurbished
AMAT Applied Materials 0020-31147 Base Insert
Alcatel Adixen ACT 1300 M / 1600 M Turbopump Controller 9097 as-is 3930-01149
Alcatel Adixen ACT 1300M / 1600M Turbopump Controller 109670 as-is 3620-00273
Nikon NCOLDCPS Power Supply Assembly 560-5501
AMAT RF Top Match 0010-08322 Rev.009 not
AMAT 0010-08322 RF Top Match Rev.002 not
AMAT Applied Materials 0010-08322 RF Top Match Rev.003 not
AMAT Quantum Leap III Power Distribution Box 9090-00482
AMAT XR80 Controller 0090-91694 ITL
TEL Tokyo Electron 3801-001132 P-8 Bridge Standard
Ebara Vacuum Turbopump ET300W
HiTek Power DC Power Supply G303/51 A1016640 Series 100
FTS Systems Water Cooled Chiller RC312ZBM1B
TEL ACT 12 300mm Process Block Robotics Arm X Axis Assy. CT2985-469941-W1
TEL ACT 12 300mm Cup Base Assy. CT2985-461034-W1 CT2985-461032-W1
TEL ACT 12 300mm CT2985-403941-W1 Rinse Resist Arm Assembly
Nikon Optistation 3 200mm Prealigner 2S013-076
LAM Research 4420 Gap Drive Control Assembly 852-017350-002
LAM Research 4420 Gap Drive Control Assembly 852-017350-003-3-C508
TEL ACT 8 Yokogawa SR1100A02 DD Servo Actuator
Brooks Automation Control Module 001-8185-06 Genus 7000
AE Advanced Energy PDX 500 RF Generator 3156024-105C 1090-13407 500W
Kensington 25-4021-0015-04 Servo Positioning Control AMAT 0190-06908 Refurbished
SMC INR-499-201 Thermo Chiller PV2-4/2-ATBSC1 C200HE untested as-is
Novellus Concecpt Two PDRS Single Source Disconnect untested as-is
IAI X-SEL Controller Lot XSEL-P-3-200IB-200IB-200IB
Inficon Preclude Gas AnalyzerTSPTW100 Untested
Verteq Transducer Transformer Set 1078234.5.1C
Digital Dynamics 27-10157-00N I/O Controller Novellus Concept II Altus
ASML 4022-437-2993 8-Channel Fiber Optics Board
Leybold DRYVAC 100P Dry Vacuum Pump missing motor as-is
Dynatronix Cell Supply 990-0296-213 127-0049-15 Semitool
Motorola MVME 147-023 Control Board 84-W8964B01B Rev. B TEL P-8
TEL ACT 12 300mm Develop Process Station Dev. Cup Assembly CT2985-413485-W1
TEL ACT 12 300mm CT2985-413485-W1 Dev. Cup Assembly CT2985-413522-W1
TEL ACT 12 300mm 2985-406656-W1 DEV SCAN (12R) ASSY Motor Scan Assembly (Right)
KLA-Tencor GPIO Board 0052412-001 Rev. AA AIT2
Hitachi I-890/900/SR CHPMEM2 Control Board I-900SRT
Nikon Power Controller RRW-07 Nikon NSR S204B 4S587-244
Mitutoyo ST320 Linear Scale Assembly Nikon NSR S204B BLECX3 4S013-313
GE Fanuc Single Board Computer VMICPCI-7325-151 0090-04266
Nikon NSR S204B S-2A5801 Optical Assembly S-EX3L3403
TEL ACT 12 300mm CT2910-205326-11 Base Under Cup CT2910-205327-11 Upper Cup Base
TEL ACT 12 CT2985-406653-W3 Right Arm Nozzle Assembly CT2986-401643-W2
Berkeley Process Control Prealigner 100-000-871-02
Metron 8500R REAC HD Assy. 215-17799-00
Electroglas Horizon 4085X Power Supply Module PSM-C
Shimadzu Vacuum Turbopump Controller EI-D3603M
Hitachi Lower Sleeve UHF 2-829605-02
Hitachi S2-84261-^A PCB Control Unit with Power Supply Surplus
Pearl Kogyo 3-83818-01R RF Generator Hitachi LP-150
SBS Technologies Hitachi M-308ATE Computer Controller 710-S00242A
Shimadzu Vacuum Turbopump Controller EI-3203MD
Seren IPS R600 RF Generator 600W As-Is
TEL Tokyo Electron 2985-427380-W1 Tube Holder Left Assembly ACT 12 200mm As-Is
SMC ITV2011-31N3N4-X95 E/P Pressure Regulator Reseller Lot of 30
Holaday HI-4433 Series Broadband Isotropic Field Probe Set
Anorad 21016401250 XY Stage Controller DR200
TEL Unity 2 Yaskawa V0SH Aligner Chamber as-is
PRI Stocker Carriage Arm Assembly BM17615 AD17615
Dynapace Single Lane 24-inch 1X Transfer Conveyor
AE Advanced Energy MDX-20K DC Power Supply 3152223-003 Rev.Y as-is
AE Advanced Energy MDX-20K DC Power Supply 3152223-003 as-is 1140-01088
LAM Research 4420 RF Generator Cart 852-014681-005-F OEM-650A
LAM Research 4420 RF Generator Cart 852-014681-005-J OEM-650A
Yaskawa 300mm Robot End Effector 300262-2006
KLA-Tencor AIT 1 RIGG 2214 SDP Frame Grabber 001052 SANP-9900
Applied Precision flowPoint Controller NanoValve Controller 52-504254-012
El-Mul Feedthrough OPFT.02 Rev.D 70509111000
KV Ltd. ASML Gas Supply Module 4022.486.23731
KV Ltd. ASML Robot Gripper Manifold 4022.486.21591
Leybold Inficon Gas Analyzer Transpector CIS 2 untested
Oramir Elmo 200mm Wafer Stage and Driver Assy.
AE LF-5 RF Generator 500W 3150012-009
Schlumberger Technologies 97913172 HCDPS PCB Assembly 40913172 Rev. 2
Bede Scientific EDRa Type A E.D.R Detector Interface
AE Advanced Energy 3150852-004 RF Generator VHF 2060 AMAT 0920-00056 As-Is
AE Advanced Energy 3150852-004 RF Generator VHF 2060 AMAT 0920-00056 Not
AE Advanced Energy 3150852-005 RF Generator VHF 2060 Not As-Is
AE Advanced Energy 3150852-004 RF Generator VHF 2060 AMAT 0920-00056 Untested
AE Advanced Energy 3150852-006 RF Generator VHF 2060 Not
AE Advanced Energy 3150292-007 RF Generator VHF Ovation 2760 Rev. D Tested As-Is
VAT 0430X-BA24-AFR1 Transfer Valve Pneumatic Actuator AMAT 0190-37105
TEL Tokyo Electron 2985-404117-W3 Side Rinse Arm Assembly ACT 12 300mm
TEL Tokyo Electron 2985-404116-W3 Side Rinse Arm Assembly ACT 12 300mm
TEL Tokyo Electron 2985-427378-W1 Right Tube Holder Assembly ACT 12 200mm As-Is
AceCo Heater Assembly S33-2180-11X Untested AS-IS
Anorad XY Axis Motion Controller 838-75003826-CR
Edwards IQDP40 Dry Vacuum Pump A532-40-905 needs to be rebuilt sold as-is
AMAT Applied Materials 0180-02403 300mm Radiance Chamber AC Incomplete, As-Is
Novellus FLVG CYL Replace Upgrade Kit 093033-797-21
Nikon Lens Module c
Kimmon Quartz Kokusai Vertron DD803V Torch Controller H-FRIM15-KDRN
Thermo Neslab 327005301603 System III Liquid Heat Exchanger as-is
Edwards QMB250 Vacuum Pump Blower lot of 5 untested and sold as-is
Yaskawa TEL Unity 2 Wafer Prealigner 200mm V0SH
Applied Materials AMAT Shutter Kit 300mm 0242-41577
TDK 4S061-925 DC Power Supply
Nikon NSR 4K990-072AN Robot Track
Pearl Kogyo RF Match M-30A2S-V 0190-30373 Rev. 002
Nikon 4S015-164 Control Board NK-C441-1
Nikon 4S587-634 PZTDriver
Nikon 4S587-754 PZTDriver
Nikon NSR-S307E IU-IOP1 Controller 4S065-171
Nikon IU-IOP2 Control Module NSR-S307E 4S065-172-1
Edwards Dry Vacuum Pump QDP80 untested U20000253
Edwards DryStar QDP80 Vacuum Pump untested
Neslab HX75 Chiller 386105021704 not
Nyquist NYCe Motion Controller NY3512/00
TEL Unity 2 TVB211-11 AvioB E67920 Board
TEL Unity 2 TVB121-1/COM 1D81-000 Board
Avio E67920 1D08-000098-12 PCB TEL Unity 2
Nikon Optistation 7 Handler Assy. KAB11240/A230-2
ENI Genesis RF Generator GHW-12Z 1250W 0190-25527
Shimadzu EI-3203MD Vacuum Turbopump Controller Tested Not
TEL ACT 12 Clean Track Flow Pressure Gauge Panel
VAT 87907-R1 Adaptive Pressure Controller Board 610PB-26NM-0002
TEL Tokyo Electron 1D81-000099-A6 Control PCB TYB111-1/MAIO
TEL ACT 12 Flow Pressure Gauge Panel
ACS-Tech80 Motion Controller SB14SYS-WF-AF-EN
Nemic-Lambda YM-01-557A DC Power Supply
Granville-Phillips 352 Gauge Controller lot of 8
SVG Coater Spindle Cont. CB40 With Pacific Sci. SCI150
AMAT Quartz Bell Jar ZCoat 0040-13509
Verity VM3200 Robot Controller
TEL Tokyo Electron 1D81-000009219 Unity II PCB TYB 121-1/COM
TEL Tokyo Electron 1D81-000009218 Unity II PCB TYB 121-1/COM
TEL Tokyo Electron ACT 12-200 2985-438909-W1 Develop Cup Assembly
Applied Materials AMAT Cassette Alignment Tool Controller LCAT200P
AJS Controls CLN-SYS-BR550-E System Board 879-8071-002-E
Toshiba VT130E3U4270 E3 Variable Torque Speed Drive Assembly
Schlumberger Control Board 97924121 Rev. D
Recif VMT8-A00530 Wafer Sorter Assembly VMT8INA0520V02
Millipore FC-2900M FC-2900MEP5 9-Pin Serial CardEdge Lot of 18 MFC AS-IS
Hitachi Transfer Robot CR-8V Complete Internals Missing Cover Untested AS-IS
AMAT Applied Materials 0270-03850 300mm Top Cover Ship Assembly
AMAT Applied Materials 0240-47946 300mm Target Locking Device Retrofit Kit
MRC Eclipse Star Power Module A117198
MRC D122986-A 200mm Eclipse Star Wafer Carousel Assembly
MECS OF101 Robot Controller
Comdel CB250 13.56MHz RF Generator FP7113RB not as-is
Pearl Kogyo M-30A2S-V RF Match 0190-30373 accessories included
Nikon PZT Driver 4S587-076 NSR
Nikon NSR Lens Assembly K-A86073
TEL PF-DB LM Cont Board 3D81-000071-VI
ENI GHW-12Z RF Generator GHW12Z-13DF2N0-001 0190-25527 2,195:13:18 hours
- 电话:13306006594
- 传真:0755-27801689
- email:3007542108@qq.com
下一篇:安科瑞直销ACR120E智能表
