产品选型
嘉兆科技 8282-1瞬态尖峰信号发生器
为MIL-STD-461B/C、GJB 151A/152A CS106尖峰信号传导敏感度测试设计制造,包含0.15 μS、 5.0 μS 、10.0 μS三种脉宽波形,最高输出电压600V。
产品分类:
仪器仪表 信号发生器 分析测试仪表
品牌:
详细信息
应用:
MIL-STD-461B/CGJB 151A/152A CS106尖峰信号传导敏感度测试设计制造,包含0.15 µS 5.0 µS 10.0 µS三种脉宽波形,最高输出电压600V
主要参数:
Spike Durations: Pushbutton selectable durations of 0.15 µS, 5.0 µS and 10.0 µS (±20%) to zero crossover, into 5.0 ohm resistive load.
Adjustable Peak Amplitude: Up to 600 volts for 0.15 µS, 5.0 µS and 10.0 µS durations into five ohm non-inductive load.
Internal Impedance: Less than 5.0 ohms for 0.15 µS, less than 2.0 ohms for 5.0 µS, less than 1.0 ohm for 10.0 µS.
Pulse Repetition Rate: Manually adjustable up to 50 p.p.s. for all pulse durations.
Pulse Shape: Ringing characteristic similar to Figure 19 in MIL-STD-462 when connected to non-inductive load
Pulse Position: Adjustable from 0° to 360° on 50 Hz, 60 Hz or 400 Hz power lines.
External Sync Operation: Remotely triggerable up to 50 p.p.s. for 0.15 µS, up to 1000 p.p.s. for 5.0 and 10.0 µS.
Amplitude Display: Panel meter is analog LED display of peak amplitude as it would be into a five ohm resistive load.
Power Current in Series Injection Mode: Handles up to 50 amperes of current at power frequencies.
Power Requirements: 115 volts 60 Hz, 3.0 amperes.(230 volts 50 Hz, 1.5 ampere available.)
Size: 12.25" wide , 8.7" high 13" deep. (311 mm x 211 mm x 330 mm.)
Weight: 30 pounds.
可选附件:
7115-2          高压脉冲变压器
7512-1          注入探头
7541-1          检测探头
8282-150      脉冲变压器
8525-1          5Ω无感电阻
8527-2          脉冲变压器
8908-1          脉冲变压器
9007-1          脉冲变压器
Chart HALT/HASS试验箱解决方案特点介绍
Chart真空绝热管道
电池管理系统测试平台
动力电池充放电系统
直流马达测试方案
