Westermo L210-F2G 网管型以太网交换机
2015/5/28 13:46:17
带路由功能的网管型以太网交换机
产品分类:工业以太网 工业交换机 物联网 网络层 以太网交换机 接入传输交换产品
品牌:威斯特蒙
产品描述 | |
Status | Active |
Article number | 3643-0105 |
Ports | 8 x RJ-45, 10 Mbit/s, 100 Mbit/s, Ethernet TX. 2 x Ethernet SFP 100 Mbit/s or 1000 Mbit/s pluggable connections (FX or TX) transceivers supported. 1 x Digital I/O. 1 x 2.5 mm jack, console. |
Description | Managed Ethernet Switch with Routing Functionality |
Warranty period | 5 Years |
认证 | |
Marine | DNV Standard for Certification no. 2.4 |
EMC (Electromagnetic Compatibility) | |
EN 61000-6-1 | Immunity residential environments |
EN 61000-6-2 | Immunity industrial environments |
EN 61000-6-4 | Emission industrial environments |
EN 55022 +A1 | Emission IT equipment |
EN 55024 | Immunity IT equipment |
FCC part 15 | Class A |
EN 50121-4 | Railway signalling and telecommunications apparatus |
IEC 62236-4 | Railway signalling and telecommunications apparatus |
EMC specifications | |
EN 61000-4-2, ESD | Contact: ±6 kV Air: ±8 kV |
EN 61000-4-4, fast transients | Power port, ±2 kV Signal ports, ±2 kV Earth port, ±1 kV |
EN 61000-4-5, surge | Power port L-E: ±0.5 kV, 12 Ω, 9 μF L-L: ±0.5 kV, 2 Ω, 18 μF L-E: ±2 kV, 42 Ω, 0.5 μF L-L: ±2 kV, 42 Ω, 0.5 μF L-E: ±2 kV, 12 Ω, 9 μF L-L: ±1 kV, 12 Ω, 9 μF Signal ports L-E: ±1 kV, 2 Ω L-E: ±2 kV, 42Ω, 0.5 μF |
EN 61000-4-8, power frequency magnetic field | 300 A/m; 0, 16.7, 50 Hz |
EN 61000-4-9, pulsed magnetic field | 300 A/m |
EN 61000-4-3, radiated RF immunity | 10 V/m @ (80 – 800) MHz 20 V/m @ (800 – 1000) MHz 10 V/m @ (1400 – 2100) MHz 5 V/m @ (2100 – 2500) MHz 1 V/m @ (2500 – 2700) MHz 1 kHz sine, 80% AM |
EN 61000-4-6, conducted RF immunity | Power port, 10 V, 80% AM, 1 kHz; (0.15 – 80) MHz Signal ports, 10 V, 80% AM, 1 kHz; (0.15 – 80) MHz Earth port, 10 V, 80% AM, 1 kHz; (0.15 – 80) MHz |
EN 55022, radiated RF emission | Class A |
FCC part 15, radiated RF emission | Class A |
EN 55022, conducted emission | Power port, Class B Signal ports, Class B |
安全 | |
Safety | UL/IEC/EN 60950-1, IT equipment |
EN 60950-1, dielectric strength | Power port to all other ports, 1.5 kVrms, 50 Hz, 1 min Signal ports to all other ports, 1.5 kVrms, 50 Hz, 1 min |
可靠性 | |
MTBF, operating | 630 000 h (MIL-HDBK-217F (Gb) 25°C) |
环境 | |
Temperature, operating | –40 to +70°C (–40 to +158°F) |
Temperature, storage | –50 to +85°C (–58 to +185°F) |
Humidity, operating | 5 to 95 % relative humidity |
Humidity, storage | 5 to 95 % relative humidity |
其他 | |
Dimensions (W x H x D) | 52.5 x 100 x 101 mm (With connectors 52.5 x 119 x 101 mm) |
Weight | 0,7 kg |
Degree of protection | IP 40 |
Cooling | Convection |
Mounting | DIN-rail |
机械性 | |
IEC-60068-2-27, shock | 30 g, 11 ms 100 g, 6 ms |
IEC 60068-2-6, vibration | 3 – 13.2 Hz: 1mm 13.2 – 100 Hz: 0.7 g 5.5 – 30 Hz: 1.5 g 30 – 50 Hz: 0.42 mm 50 – 500 Hz: 4.2 g |
IEC 60068-2-27, bump | 10 g, 11 ms |
电源口规格 | |
Operating voltage | Rated: 24 to 48 VDC Operating: 19 to 60 VDC |
Rated current | 240 mA @ 24 VDC 120 mA @ 48 VDC |
Rated frequency | DC |
Inrush current | 22.7·10-3 A2s @ 48 VDC |
Startup current | 2 x Rated current |
Polarity | Reverse polarity protected |
Redundant power input | Yes |
Isolation to | All other |
Connection | Detachable screw terminal |
Connector size | 0.2 – 2.5 mm2 (AWG 24 – 12) |
Shielded cable | Not required |
10/100BaseTX规格 | |
Electrical specification | IEEE std 802.3. 2005 Edition |
Data rate | 10 Mbit/s, 100 Mbit/s, manual or auto |
Duplex | Full or half, manual or auto |
Circuit type | TNV-1 |
Transmission range | Up to 150 m with CAT5e cable or better |
Connection | RJ-45, auto MDI/MDI-X |
Shielded cable | Not required, except when installed in Railway applications as signalling and telecommunications apparatus and located close to rails. |
Conductive housing | Yes |
Number of ports | 8 |
100/1000SFP规格 | |
Optical/Electrical specification | IEEE std 802.3. 2005 Edition |
Data rate | 100 Mbit/s or 1000 Mbit/s transceivers supported |
Duplex | Full or Auto, depending on transceiver |
Transmission range | Depending on tranceiver |
Connection | SFP slot holding fibre transceiver or copper transceiver |
Number of ports | 1 or 2 |
I/O relay output | |
Maximum voltage / current | 60 VDC / 80 mA |
Connect resistance | Max 30 Ω |
I/O Digital output | |
Maximum volt / current | 60 VDC / 2 mA |
Voltage_levels | Logic one: >12V Logic zero: <1V |
Interface specifications, console | |
Electrical specification | TTL-level |
Data rate | 115.2 kbit/s |
Data format | 8 data bits, no parity, 1 stop bit, no flow control |
Circuit type | SELV |
Connection | 2.5 mm jack, use only Westermo cable 1211-2027 |
Westermo新产品DDW-142
Westermo荣获2015年中国轨道交通行业十大工业以太网交换机
Westermo交换机为海洋石油开发提供至关重要的可靠保障
Westermo EDW-120串行适配器
Westermo EDW-100串行适配器
