业界动态
infoteam OpenPCS v6.6.4 震撼发行
infoteam OpenPCS v6.6.4震撼发行。现在我们有德语和中文简体两种语言版本。
此版本的新特性:
Fixed CRQs
2012/0061
Error not displayed at the end of build log
Some errors are not considered the sum of error
2012/0059
Ordering logic for FB categories
FB categories are ordered in alphabetial order
2012/0050
Build faild after a direct global file is moved to sub folder
Build now recognizes the moved fiel
2012/0047
Library files not included after upload from PLC
Library files are inculuded in upload if option is selected
2012/0045
Error in online change
Changing only initial values has lead to default values for the whole segment
2012/0039
Some function block help files are missing
Links to the help pages in openpcs.xml are now included
2012/0035
Chinese comments in LD instructions
Chinese comments are displayed correct
2012/0029
SoftPLC task crash because of too many segments
The number of segments is chechked and an error is thrown
2012/0027
Program global FBs do not work
Function block decalred in program global section now work
2012/0023
Error reading hardware file in 663
In some cases error messages have been entries were in english
2012/0012
Wrong language in context menu
In German OpenPCS some context menu entries were in english
2012/0007
Address as variable name is watchlist
Using direct address as watch variable is working again
2012/0003
Pass wrong parameter type before function block call
The error message was improved
新发版本链接如下:
· Release notes: http://www.infoteam.de/downloads/login/openpcs66/ps/OpenPCS_664_ReleaseNotes.pdf
· German version: http://www.infoteam.de/downloads/shared/PS664d.exe
· Chinese version: http://www.infoteam.de/downloads/shared/PS664cs.exe
一方梯队软件(北京)有限公司迁址通知
医疗器械软件技术标准研讨会圆满落幕
一方梯队 OpenPCS 冗余系统
一方梯队软件“2015中国安全技术日”圆满落幕
一方梯队“2015中国安全技术日”如期与您见面
