技术 |
| IEEE802.3 10Base-T IEEE802.3u 100Base-TX IEEE802.3ab 1000Base-T IEEE802.3z Gigabit Ethernet Fiber IEEE802.3x flow control and back pressure IEEE802.1p Class of Service |
性能 |
| 14,880pps for 10M Ethernet,148,800pps for 100M Fast Ethernet, 1,488,100 for Gigabit Ethernet |
| 64 bytes ~ 1522 bytes (含 VLAN Tag) |
| 符合IEEE802.1p class of service, 每个端口支持4个优先级 8 (Higher):4(High):2(Low):1(Lower) scheduling. Tag Priority ID: Higher (6,7), High (4,5), Low (0,3), Lowest (1,2) |
界面 |
| 7 x 10/100 Base-TX withAuto MDI/MDI-X function Auto-Negotiation 3 x 1000Base-Tsupports Auto MDI/MDI-X ,Auto-Negotiation ,SFP socket Gigabit Port10: 1000Base-T (1000Mbps) / Gigabit Fiber Gigabit port8/9: 10/100/1000Mbps / Gigabit Fiber |
| 10/100 Base-TX: RJ-45 1000Base-T: RJ-45 SFP: 支持全部3.3v SFP 类型千兆光纤收发器 电源: 4-Pin可拆卸接线槽 |
| RJ-45接头: 支持CAT-3, CAT-4, CAT-5屏蔽或非屏蔽双绞线。 最大传输距离100米。 |
| 电源:Power 1 (Green), Power 2 (Green) 10/100 Mbps RJ-45 port: Link/Activity (Green), Full Duplex/ Collision (Yellow) port: Link/Activity(Green) 1000Base-TRJ-45 port: Link/Activity (Green) SFP: Link/Activity (Green) |
电源要求 |
| 4-Pin可拆卸接线槽 冗余电源DC 24V (12~48V)支持正负极性反接保护 |
| 11.5 Watts @ DC 24V(Maximum) |
机械规格 |
| 137mm(H) x 96mm (W) x 119mm (D) |
工作环境 |
| JetNet3010G: -20 ~ 70°C JetNet3010G-w: -40 ~ 70°C |
通过认证 |
| EN61000-4-2, EN61000-4-3, EN61000-4-4, EN61000-4-5, EN61000-4-6, EN61000-4-8, EN61000-4-11 |
