集智达 REMO-3220 无风扇嵌入式计算机
2006/8/8 0:00:00
AMD Geode™ LX800 无风扇设计 2个 RS232 和2个RS422/485
产品分类:品牌:
集智达智能
*AMD Geode™ LX800 无风扇设计
*2个 RS232 和2个RS422/485 (自动数据流量控制)
*NVRAM 插槽可选 SRAM类型内存备份
*Type I/II PC 卡 (PCMCIA)
*CompactFlash 插槽, VGA, USB Port, LPT, KB, Mouse, Ethernet 和 Audio
*DC 电源输入:+9 V ~ +36 V
*可选备份底板作为二级系统的扩展
Specifications
主板
·ICES 120 ETX Module
·Supports ETX Module with AMD LX800 Processor, VGA/ISA/PCI/IDE/LVDS /Audio/COM/LPT/USB2 .0/LAN Interface
内存
·One 200-pin SODIMM socket for up to 1 GB Non-ECC Non- registered DDR SDRAM memory
驱动
·Front access PCMCIA socket x 1
·Internal CompactFlash socket x 1
·Internal 2.5” HDD drive bay x 1
前面板
·I/O 接口 Front I/O Ports
·Power / HDD Status LEDs
·2 LEDs, connect to GPIO, programmable for alarm or other application specific purposes
·PCMCIA Socket x 1
·DB9 COM1 and COM2; Screw Terminal COM3 and COM4
·USB 2.0 x 2
后面板
·I/O 接口 RJ45 with LED connector x 2
·USB 2.0 Ports x 2, KB/Mouse connector x 1
·+9 V to +36 V DC power input
·Power Reset Button
·VGA Connector (DB15)
·Audio-out and Mic-in Connector
·LPT Port x 1
扩展槽
·PCI Expansion, PCMCIA x 1
·2nd floor expansion design:
·A.Slim CD-ROM Expansion Kit
·B.PCI 104 Module Expansion Kit
体积
·260 mm (W) x 176 mm (D) x 55 mm (H)
环境
·Operating temperature:
·Ambient with air flow: 0°C to 40°C
·NICE 3200 Tcase (Surface Temperature of Chassis):5°C to 40°C (W/HDD)/0°C to 45°C (W/CF card only)
·Storage temperature: -20°C to 80°C
·Relative humidity: 10% to 90% (Non-condensing)
认证
·CE approval
·FCC Class A
Ordering Information
·NICE 3220-LX8 :
(符合RoHS 规范)AMD Geode LX800 无风扇设计
·2个 RS232 和 2个RS422/485 (Automatic Flow Control and Isolation)
·NVRAM 插槽,可选 SRAM类型内存备份
·Type I/II PC 卡 (PCMCIA), CompactFlash Socket, VGA, USB Port, LPT, KB,Mouse, Ethernet and Audio
·DC电源输入:+9 V ~ +36 V
Optional :
·电源适配器(24V out)
*可选备份底板作为二级系统的扩展
Specifications
主板
内存
驱动
前面板
·PCMCIA Socket x 1
·USB 2.0 x 2
后面板
·Power Reset Button
·LPT Port x 1
扩展槽
体积
环境
认证
·CE approval
·FCC Class A
·NICE 3220-LX8 :
Optional :
·电源适配器(24V out)
上交会商用密码展|集智达商用密码硬件平台为商密建设助力
深圳网络安全展,集智达收获青睐载誉而归
聚以致远 共行万里 集智达携手绿盟探索网络安全新机遇
集智达&网迅续签战略合作:携手共进,合作共赢!
集智达RK3568处理器的MXM接口核心板GME-3601
