研扬PCM-8500 3.5"嵌入式单板
2010/7/2 14:14:00
GENE-9455 adopts the latest Intel Atom N270 Processor and the system memory is deployed with SODIMM DDRII 400/533 up to 2GB. In addition, Intel 82574L supports two 10/100/100Base-TX that allows network connections.
产品分类:嵌入式系统 物联网 单板电脑 应用层 嵌入式应用
品牌:研扬科技
AAEON, a leading embedded boards manufacturer, is pleased to announce the debut of their new generation 3.5 SubCompact BoardGENE-9455. The GENE-9455 is a cutting-edge product that provides high performance and low power consumption in the embedded market.
GENE-9455 adopts the latest Intel Atom N270 Processor and the system memory is deployed with SODIMM DDRII 400/533 up to 2GB. In addition, Intel 82574L supports two 10/100/100Base-TX that allows network connections. This model applies one Mini PCI and one ECX Proprietary expansion. Moreover, one EIDE, two SATA II and one Type II CompactFlash storages are configured on the GENE-9455. In addition to the diverse storages, GENE-9455 also equips four USB2.0, two COM, one keyboard/mouse ports for flexible I/O expansions. There is no more worries about installing many necessary devices to complete the functions of your system.
The display of GENE-9455 supports CRT/LCD simultaneous/ dual view displays and is up to 18-bit dual-channel LVDS. This brand new SubCompact board is developed to cater to the requirements of Automation, Medical, ticket machine, transportation, gaming, KIOSK, and POS/POI applications. 系统
- 类型
3.5" - 处理器
板载Intel® Atom™ N270处理器1.6 GHz , FSB 533 MHz - 系统内存
200 pin DDRII SODIMM x 1, 最大2 GB (DDRII 400/533) - 芯片组
Intel® 945GSE + ICH7M - I/O芯片组
ITE8781 - 以太网
Intel® 82574L, 10/100/1000Base-TX, RJ-45 x 2 - BIOS
Award Plug & Play SPI BIOS - 2 MB Flash - 网络唤醒
支持 - 监视定时器
可编程超时中断或系统复位 - 硬件状态监测
支持电源电压和温度监测 - 扩展接口
Mini-PCI x 1 & ECX专用扩展 x 1 - 电池
锂电池 - 供电方式
+8.5V 到+19V宽幅DC输入(AT) 或+5V (AT/ATX) - 功耗(标准)
Intel® Atom™ N270, DDRII 667 2 GB
2.89A@ +5V - 主板尺寸
5.75" (L) x 4" (W) (146mm x 101.6mm) - 总重
0.88 lb (0.4 kg) - 工作温度
32oF ~ 140oF (0oC ~ 60oC) - 存储温度
-40oF ~ 176oF (-40oC ~ 80oC) - 工作湿度
0% ~ 90%相对湿度, 无冷凝 - MTBF (小时)
70,000
显示: 支持CRT/LCD同步/ 双显
- 芯片组
Intel® 945GSE集成 - 显存
共享系统内存最大224 MB/ DVMT3.0 - 分辨率
最大2048 x 1536 CRT
最大1024 x 768 LCD - LCD 接口
最大支持18位双通道LVDS - TV-out
支持NTSC & PAL 标准S端子和复合视频 - DVI (选配)
DVI-I x 1
I/O
- 存储
EIDE x 1 (UDMA-100用于两台设备), SATA x 2, Type II CF x 1 - 串口
RS-232 x 3, RS-232/422/485 (自动流量控制) x 1 - USB
USB2.0 x 4 - PS/2口
键盘 x 1, 鼠标 x 1 - 数字I/O
支持 8位 (可编程) - 音频
Line-in, Line-out, Mic-in & CD-in - 触摸屏(选配)
支持4/5/8线
官宣!研扬人工智能馆盛大开业啦~
研扬科技BOXER-6405U智能边缘计算平台
研扬科技 | 应用案例分享 || 将边缘计算引入面部识别应用
研扬科技 | FWS-8600网络设备为人工智能网络和数据中心注入新动力
研扬科技 | 由英特尔酷睿处理器驱动的紧凑型完整解决方案
