研扬 POP-70 POP平板电脑
2010/4/19 10:20:06
研扬 POP-70 POP平板电脑板载Intel Celeron M低压CPU 7.0" WVGA 彩色TFT LCD显示,开放式框架设计,支持Windows 2000, Windows XP, Windows XP Embedded,支持触摸屏。
产品分类:工控机 工控机整机 平板电脑(PPC)
品牌:研扬科技
The POP-70 Point of Promotion Panel PC is an Intel 600MHz/ 1.5GHz processor computer that is designed to serve as a Digital signage market. It is a PC-based system with 7.0" color TFT LCD display, on-board Ethernet controller, multi-COM port interfaces and an audio controller. With a built-in Compact Flash socket, the POP-70 is as compact and user friendly as a multi-function computer. In addition, its Open-frame design makes it fitted to a variety of cutout installation in building & public field. In addition, it can be wall mounted or DIN Rail mounted.
For system integrators, this simple, complete, compact and highly integrated system let you easily build a point of promotion into your applications. Common industrial applications include factory automation systems, precision machinery, and production process control. It is also suitable for many non-industrial applications, including vending machine, and car park automation. Our point of promotion panel pc is a reliable & cost-effective solution to your daily business.
系统
- 处理器:Intel Celeron M 1.5GHz /600MHz
- 内存(选配):512 MB (最大 1G)
- LCD/CRT控制器:Intel 852GM
- 以太网:10/100 Base -TX ,RJ-45接口 x 1 (选配)
- I/O口:RS-232 x 1、RS-232/422/485 x 1、USB2.0 x 2、Audi Line out x 1 (选配)
- SDD :2.5"HDD磁盘架/CF插槽 (内置)
- 扩展槽:Mini PCI 插槽 x 1 (内置)
- OS:支持W indows 2000, Windows XP, Windows XP Embedded
结构
- 构造:开放式框架
- 前面板颜色:SGCC 金属色
- 安装:VESA 75
- 尺寸:190.5mm(宽) x 170mm (高) x 70.4mm (长) (7.5" x 6.69" x 2.77")
- 净重:1.2Kg
- 总重:2Kg
环境
- 工作温度:0oC ~ 40oC (32oF ~ 104oF)
- 存储温度:-20oC ~ 60oC (-4oF ~ 140oF)
- 存储湿度:10% 到90%@ 40oC, 无冷凝
- 振动:随机运行1G, 5~500Hz
- 冲击:15G峰值加速度 (持续11秒)
- 安全:UL60950
- EMC :CE/ FCC Class A
供电
- DC-DC输入:输入范围9V~30VDC
LCD
- 显示类型:7.0" TFT-LCD
- 最大分辨率:800 x 480
- 最大色彩:262K 色彩
- 光点尺寸:0.1905 x 0.1905
- 亮度(标准):320 cd/m2
- 视角:120o (高) / 110o (宽)
- 背光MTBF (小时) :20,000
触摸屏
- 类型:4-wire, 模拟电阻式
- 分辨率:2048 x 2048
- 透光率:>79%
- 寿命:1千万次激活
官宣!研扬人工智能馆盛大开业啦~
研扬科技BOXER-6405U智能边缘计算平台
研扬科技 | 应用案例分享 || 将边缘计算引入面部识别应用
研扬科技 | FWS-8600网络设备为人工智能网络和数据中心注入新动力
研扬科技 | 由英特尔酷睿处理器驱动的紧凑型完整解决方案
