研扬 POP-150 POP平板电脑
2010/4/19 10:18:25
研扬 POP-150 POP平板电脑板载Intel Celeron M 低功耗处理器,15" XVGA 彩色 TFT LCD显示,开放式构架设计,经济型解决方案。
产品分类:工控机 工控机整机 平板电脑(PPC)
品牌:研扬科技
The POP-150 Point of Promotion Panel PC is an IntelR CeleronR M 1.5GHz/ 600MHz processor computer that is designed to serve as a Digital signage market. It is a PC-based system with 15" color TFT LCD display, onboard Ethernet controller, multi-COM port interfaces and an audio controller. With a built-in Compact Flash socket, the POP-150 is as compact and user friendly as a multi-function computer. In addition, its Open-frame design makes it fitted to a variety of cutout installation in building & public field. In addition, it can be wall mounted or DIN Rail mounted.
For system integrators, this simple, complete, compact and highly integrated system let you easily build a point of promotion into your applications. Common industrial applications include factory automation systems, precision machinery, and production process control. It is also suitable for many non-industrial applications, including vending machine, and car park automation. Our point of promotion panel pc is a reliable & cost-effective solution to your daily business.
系统
- 处理器: IntelR CeleronR M 1.5GHz/ 600MHz
- 系统内存: 512 MB
- LCD/CRT 控制器: IntelR 852GM
- 以太网: 10/100Base -TX ,RJ-45 x 1 (选配)
- I/O 接口:
RS-232 x1, RS-232/422/485 x 1
USB2.0 x 2
音频输出x 1
PS/2 x 1 (键盘 + 鼠标 Mini-DIN) - 存储器: 2.5" HDD支架/ CF插槽 (内置)
- 扩展插槽: Mini PCI x 1 (内置)
- 操作系统:WindowsR 2000, WindowsR XP, WindowsR XP Embedded
结构
- 构造: 开放式
- 颜色:SGCC金属色
- 安装:VESA 100
- 尺寸: 382mm x 295mm x 60 mm(15" x 11.61" x 2.36")
- 净重: 7kg (15.4lb)
环境
- 工作温度: 0oC ~ 40oC (32oF ~ 104oF)
- 存储温度: -20oC ~ 60oC(-4oF ~ 140oF)
- 存储湿度: 10% ~ 90% @ 40oC, 无冷凝
- EMC: CE/ FCC Class A
电源
- DC-DC 输入:
输入范围: 9V~30VDC
LCD
- 显示类型: 15" TFT-LCD
- 最大分辨率:1024 x 768
- 最大色彩: 16.7M 彩色
- 点距:0.297 x 0.297
- 亮度:250 nits (TYP.)
- 视角: 150o(H)/140o(V)
- 背光 MTBF: 30,000
触摸屏
- 类型:5线,电阻式
- 分辨率:2048 x 2048
- 透光率:80%
- 寿命:35 百万次激活
官宣!研扬人工智能馆盛大开业啦~
研扬科技BOXER-6405U智能边缘计算平台
研扬科技 | 应用案例分享 || 将边缘计算引入面部识别应用
研扬科技 | FWS-8600网络设备为人工智能网络和数据中心注入新动力
研扬科技 | 由英特尔酷睿处理器驱动的紧凑型完整解决方案
