关键字: | 监控主板,4路视频主板,工业主板 |
产品分类: | 工控机 |
品牌: |
- 产品简介:
- 产品特点: 支持Intel Core Duo / Core 2 Duo 处理 , 板载4~16 Video-in , PCI / Mini PCI / Mini card , SATA , LVDS / Touch Screen controller
Intel Core Duo / Core 2 Duo solution , 4~16 Video-in , PCI / Mini PCI / Mini card , SATA , LVDS / Touch Screen controller
具体规格:
. CPU type:
前端总线:
533/667 MHz
主板芯片 :
Intel 945GME/GM + ICH7M (82801GBM)
图像显示 :
Intel Gen 3.5 Integrated Graphics Engine
Dynamic Video Memory Technology(DVMT 3.0)
Higher performance MPEG-2 decoding
. LVDS :
Supports data format of 18 bits/36 bits
内存 :
2x DDR2 SODIMM(max. 4GB)
. IDE :
Ultra ATA 100/66/33, 1x 40 pin 2.54mm
Support Compact Flash card type II for ATA interface
. SATA :
Two SATA ports with independent DMA operation supported
声卡 :
Intel High Definition Audio Specification Rev.1.0 Compliant
. LAN :
1 x Realtek RLT8101E 10/ 100 Mbps (optional Realtek/Intel
Gigabit)
Supports PCI Express™ 1.0a
. IO功能 :
3~5x RS232, 1xRS232/422/485
Supports PS2 keyboard and mouse
视频输入 :
4~16 ports with Conexant CX25878 PCI chipset
. USB
8* USB 2.0 (2 external+6 internal)
. 触摸屏(可选)
USB/COM interface Touch screen controller
支持 4- , 5- , 8-线阻触屏
USB 1.1full speed sample rate max. (300points/s)
. DIO & 看门狗 :
Hardware digital Input & Output, 8xDI / 8xDO
Hardware Watch Dog Timer, 0~255 sec programmable
扩展界面 :
1* Mini PCI for only PCI rev: 2.2 interface
1* PCI gold finger for only PCI rev: 2.2 interface
1* Mini card for USB (option)
电源 :
On board power DC +12V±5% convert into system
+3.3V/+12V/+5V
尺寸 :
200 x 150 mm
工作温度 :
0 ~ 60°C
运行湿度 :
5~95% @ 60°C, non-condensing
