华耀电子 ESP-60 60W单路输出平板开关电源
2011/12/2 13:10:04
华耀电子60W单路输出平板开关电源产品特性: 全范围AC输入恒压/恒流功能短路、过载、过压、过温保护适用于LED显示、工业控制 LED通电指示 3年质保
产品分类:工业电源 开关电源
品牌:产品介绍
产品特性: | Product features: | ||
l 全范围AC输入 | l Universal AC input/full range | ||
l 恒压/恒流功能 | l Constant voltage or constant current(CV+CC) | ||
l 短路、过载、过压、过温保护 | l Protections: short circuit/overload/over voltage /over temperature | ||
l 适用于LED显示、工业控制 | l Suitable for led display industry control | ||
l LED通电指示 | l LED indicator for power on | ||
l 3年质保 | l 3 years warranty | ||
技术参数: | Specifications: | ||
输入电压 | 90~264VAC | input voltage | 90~264VAC |
常规100~240 VAC | Nominal 100~240 VAC | ||
输入频率 | 47~63Hz | Input frequency | 47~63Hz |
冲击电流 | 40A@230VAC, 满载冷态 | Inrush current | 40A@230VAC, full load cold start |
维持时间 | >20ms@ 230VAC满载 | Hold up time | >20ms@ 230VAC full load |
过载保护 | 110%~150% | Overload protection | 110%~150% |
过压保护 | 110%~145% | Over voltage protection | 110%~145% |
运行温度 | -20℃~ 70℃, 实据降额曲线 | Operating temperature | -20℃~ 70℃, refer to output derating curve |
安全标准 | EN60950 | EN60950 | |
EMC标准 | EN55022 Class B | Safety standards | EN55022 Class B |
MTBF | 200kHrs at 25℃ | EMC standards | 200kHrs at 25℃ |
绝缘标准. | I/P-O/P: 1.5KVAC,1min | MTBF | I/P-O/P: 1.5KVAC,1min |
I/P-FG:1.5KVAC,1min | Withstand voltage | I/P-FG:1.5KVAC,1min | |
O/P-FG:0.5KVAC,1min | O/P-FG:0.5KVAC,1min | ||
重 量 | 0.4Kg/pcs | Weight | 0.4Kg/pcs |
P/N | Output | Tol. | R&N | Effi. | Load Regulation | DC adjustment range |
产品型号 | 输出 | 容差 | 纹波&噪声 | 效率 | 负载调整率 | DC可调范围 |
ESP-60-12 | 12V,5A | ±3% | 120mV | 84% | ±2% | 10.8V ~13.2V |
ESP-60-15 | 15V,4A | ±3% | 120mV | 87% | ±2% | 13.5V ~16.5V |
ESP-60-18 | 18V,3.3A | ±3% | 150mV | 88% | ±2% | 16.2V ~19.8V |
ESP-60-24 | 24V,2.5A | ±3% | 240mV | 88% | ±2% | 21.6V ~26.4V |
ESP-60-36 | 36V,1.6A | ±3% | 240mV | 89% | ±2% | 32.4V ~39.6V |
ESP-60-48 | 48V,1.25A | ±3% | 240mV | 89% | ±2% | 43.2V ~52.8V |
华耀将参加慕尼黑上海电子展(electronica China 2018)
华耀电源参展第十届中国国际国防电子展览会
华耀电子即将参加2016年中国国际电梯展览会
华耀电子与您相约2016福州体博会
华耀电子即将参加2016年慕尼黑上海电子展
