Direct-Link
产品系列包括大量产品,比如智能连接器、网关、针对现场总线的专用板卡以及适用于工业网络的软件解决方案。
产品分类:工业以太网 现场总线
品牌:Woodhead
Direct-Link
Direct-Link产品20多种:EtherNet,TCP/IO,Profibus-DP,CANopen,DeviceNet,Siemens S7/MPI及串口连接等等。 Direct-Link产品具有简单易用和实施迅速的特点。
部分产品:
Ethernet Switches and Accessories | |
DRL-111-MSC |
Industrial Ethernet to Fiber Rail Converter, 1 RJ45 to 1 Multi Mode 100 Base FX, SC Connector |
DRL-111-MST |
Industrial Ethernet to Fiber Rail Converter, 1 RJ45 to 1 Multi Mode 100 Base FX, ST Connector |
DRL-111-SSC |
Industrial Ethernet to Fiber Rail Converter, 1 RJ45 to 1 Single Mode 100 Base FX, SC Connector |
DRL-111-SST |
Industrial Ethernet to Fiber Rail Converter, 1 RJ45 to 1 Single Mode 100 Base FX, ST Connector |
DRL-241-MSC |
Industrial 5-port Entry-Level Ethernet Rail Switch, Unmanaged, 4 RJ45, 1 MM FX, SC connector |
DRL-241-MST |
Industrial 5-port Entry-Level Ethernet Rail Switch, Unmanaged, 4 RJ45, 1 MM FX, ST connector |
DRL-241-SSC |
Industrial 5-port Entry-Level Ethernet Rail Switch, Unmanaged, 4 RJ45, 1 SM FX, SC connector |
DRL-241-SST |
Industrial 5-port Entry-Level Ethernet Rail Switch, Unmanaged, 4 RJ45, 1 SM FX, ST connector |
DRL-250 |
Industrial 5-port Entry-Level Ethernet Rail Switch, Unmanaged |
DRL-280 |
Industrial 8-port Entry-Level Ethernet Rail Switch, Unmanaged |
DRL-281-MSC |
Industrial 9-port Entry-Level Ethernet Rail Switch, Unmanaged, 8 RJ45, 1 MM FX, SC connector |
DRL-281-MST |
Industrial 9-port Entry-Level Ethernet Rail Switch, Unmanaged, 8 RJ45, 1 MM FX, ST connector |
DRL-281-SSC |
Industrial 9-port Entry-Level Ethernet Rail Switch, Unmanaged, 8 RJ45, 1 SM FX, SC connector |
DRL-281-SST |
Industrial 9-port Entry-Level Ethernet Rail Switch, Unmanaged, 8 RJ45, 1 SM FX, ST connector |
DRL-290 |
Industrial 9-port Entry-Level Ethernet Rail Switch, Unmanaged |
DRL-350 |
Industrial 5-port Ethernet Rail Switch, RJ45, Managed, redundant power |
DRL-332-MSC |
Industrial 5-port Web managed Ethernet Rail Switch, 3 RJ45, 2 Multi Mode 100 base FX, SC connector, redundant power |
DRL-332-MST |
Industrial 5-port Web managed Ethernet Rail Switch, 3 RJ45, 2 Multi Mode 100 base FX, ST connector, redundant power |
DRL-332-SSC |
Industrial 5-port Web managed Ethernet Rail Switch, 3 RJ45, 2 Single Mode 100 base FX, SC connector, redundant power |
DRL-332-SST |
Industrial 5-port Web managed Ethernet Rail Switch, 3 RJ45, 2 Single Mode 100 base FX, ST connector, redundant power |
DRL-362-MSC |
Industrial 8-port Web managed Ethernet Rail Switch, 6 RJ45, 2 Multi Mode 100 base FX, SC connector, redundant power |
DRL-362-MST |
Industrial 8-port Web managed Ethernet Rail Switch, 6 RJ45, 2 Multi Mode 100 base FX, ST connector, redundant power |
DRL-362-SSC |
Industrial 8-port Web managed Ethernet Rail Switch, 6 RJ45, 2 Single Mode 100 base FX, SC connector, redundant power |
DRL-362-SST |
Industrial 8-port Web managed Ethernet Rail Switch, 6 RJ45, 2 Single Mode 100 base FX, ST connector, redundant power |
DRL-380 |
Industrial 8-port Ethernet Rail Switch, RJ45, Managed, redundant power |
DRL-EDS-OPC-BSC |
SNMP data server, Basic, OPC version 2.0, up to 50 devices |
DRL-EDS-OPC-EXP |
SNMP data server, Expert, OPC version 2.0, up to 50 devices, with network analyst and template generator |
DRL-EDS-OPC-ENT |
SNMP data server, Enterprise, OPC version 2.0, unlimited devices, with network agent |
PC Network IO Interface Cards |
PROFIBUS DP |
DRL-DPM-PCI |
Direct-Link PCI-DPIO Profibus DP Master/slave card PCI 5V |
DRL-DPM-104 |
Direct-Link PC104-DPIO Profibus DP Master/slave card PC/104 |
DRL-DPM-104-9 |
DRL-DPS-104 |
Direct-Link PC104-DPSIO Profibus DP slave card PC/104 |
DRL-PFB-USB |
Direct-Link Profibus DP USB Adapter |
DRL-PFB-USB-DLL |
Direct-Link Profibus DP USB DLL ,High-Speed USB Adapter, Full PROFIBUS® (DP, S5, S7/MPI), |
DRL-UPS-USB |
Direct-Link Upgrade license from DLL Library only with all Data Servers |
PROFIBUS MPI/S7 |
DRL-MPI-USB |
Direct-Link USB100PFB Profibus MPI/S7, USB adapter (Windows 2000, 2003, XP) |
DRL-MPI-PCU |
Direct-Link PCU100PFB Profibus MPI/S7 card Universal PCI |
DRL-MPI-USB-DLL |
Direct-Link High-Speed USB Adapter, MPI/S7, DLL Library only |
DEVICENET |
DRL-DVN-PCI |
Direct-Link PCI-DVNIO DeviceNet Master/Slave card PCI 5V |
DRL-DVN-PCU |
Direct-Link PCU-DVNIO DeviceNet Mstr/Slave card Univ. PCI |
DRL-DVN-104 |
Direct-Link PC104-DVNIO DeviceNet Master/Slave card PC/104 |
CANopen |
DRL-CNO-PCI |
Direct-Link PCI-CANIO CANopenmastercard PCI 5V |
DRL-CNO-104 |
Direct-Link PC104-CANIO CANopenmasterPC/104 card |
ETHERNET |
DRL-EIO-PCU |
Direct-Link PCU-ETHIO EthernetI/O card (Ethernet IP, Modbus TCP) Universal PCI |
Non-Windows driver - For DRL-DPM, DRL-DVN, DRL-CNO, DRL-ETH (ask for compatibility) | |
DRL-DRV-DOS |
Direct-Link IO driver for MS-DOS, download from WEB (Freeware) |
DRL-DRV-QNX |
Direct-Link IO driver for QNX,download from WEB (Freeware) |
DRL-DRV-VXW |
Direct-Link IO driver for VX-Works, download from WEB (Freeware) |
DRL-DDK-LNX |
Direct-Link IO driver development toolkit for Linux, download from WEB (Freeware) |
PC Communication Software Interfaces |
Ethernet TCP/IP & Serial Direct-Link range (Software stack using generic card) |
DRL-ALL-SWL-P |
Direct-Link SW1000ETH/SER Eth. TCP/IP + Serial all protocol, 1000 tags, Parallel dongle |
DRL-ALL-SWL-S |
Direct-Link SW1000ETH/SER Eth. TCP/IP + Serial all protocol, 1000 tags, Software key |
DRL-ALL-SWL-U |
Direct-Link SW1000ETH/SER Eth. TCP/IP + Serial all protocol, 1000 tags, USB |
DRL-ALL-SWF-P |
Direct-Link SW1000ETH/SER Eth. TCP/IP + Serial all protocol, Full tags, Parallel dongle |
DRL-ALL-SWF-S |
Direct-Link SW1000ETH/SER Eth. TCP/IP + Serial all protocol, Full tags, Software key |
DRL-ALL-SWF-U |
Direct-Link SW1000ETH/SER Eth. TCP/IP + Serial all protocol, Full tags, USB |
DRL-DTB-SWF-P |
Data-base server full tags, no protocol, parallell key |
DRL-DTB-SWF-S |
Data-base server full tags, no protocol, software key |
DRL-DTB-SWF-U |
Data-base server full tags, no protocol, USB key |
DRL-UPG-SWF |
Direct-Link SW1000ETH/SER upgrade from 1000 to Full tags |
Gateway |
DRL-2ASI-CAN |
Direct-Link Gateway, 2 channel ASI to CANopen |
DRL-2ASI-DN |
Direct-Link Gateway, 2 channel ASI to DeviceNet |
DRL-2ASI-ETH |
Direct-Link Gateway, 2 channel ASI to Ethernet |
DRL-2ASI-PFB |
Direct-Link Gateway, 2 channel ASI to Profibus |
DRL-2ASI-SER |
Direct-Link Gateway, 2 channel ASI to Modbus Serial |
DRL-DVN-SRE |
Direct-Link Gateway, DeviceNet to Serial/Ethernet |
DRL-PFB-SRE |
Direct-Link Gateway, Profibus to Serial/Ethernet |
DRL-DPS-SRM |
Direct-Link Gateway, Profibus to Modbus Serial |
Direct Link Diagnostic Accessories |
MA9D00-42 |
Profibus D-Sub 9-pin attach horizontal connector with Diagnostics |
PA9D01-42 |
Profibus D-Sub 9-pin attach vertical connector with Diagnostics |
PA9S01-42 |
Profibus D-Sub 9-pin attach vertical connector without Diagnostics |
PBSTRIP |
Cable stripping tool for Profibus media |
DN-MTR |
NetMeter for DeviceNet |
DN-MTR-CAL |
NetMeter Calibration Testing |
DN-MTR-BAG |
Nylon Carrying Case for NetMeter and other Diagnostic Tools |
715-0016 |
NetMeter User’s Guide |
DN3020PM-1 |
DeviceNet PowerMonitor - Tee - male to female |
DN3020PM-3 |
DeviceNet PowerMonitor - Tee - female to male |
115011A-PM-1 |
DeviceNet PowerMonitor - in-line - male to female |
115011A-PM-3 |
DeviceNet PowerMonitor - in-line - female to male |
115011NB-PM-1 |
DeviceNet PowerMonitor; nickel-brass coupling - in-line - male to female |
115011NB-PM-3 |
DeviceNet PowerMonitor; nickel-brass coupling - in-line - female to male |
115011SS-PM-1 |
DeviceNet PowerMonitor; stainless steel coupling - in-line - male to female |
115011SS-PM-3 |
DeviceNet PowerMonitor; stainless steel coupling - in-line - female to male |
DNETEXT-C |
DeviceNet Bus Extender |
GE智能平台“Proficy 新产品、新应用”客户交流会成功举行
GE智能平台“Proficy 新产品、新应用”客户交流会研讨会
[典型应用]谁说小型污水厂不能实现智能运营管理
[典型应用]看GE智能平台如何帮助丹麦哥本哈根机场全面提升运营效率
[典型应用]GE智能平台助力康奈尔大学提升校园运营管理
