GATEway
Woodhead GATEway is more than a standard tunneling gateway. This is the first solution that allows connecting devices over up to 14 different Ethernet and Serial protocols using a single hardware platform.
产品分类:现场总线 工业以太网 物联网 网关 网络层 接入传输交换产品
品牌:Woodhead
Open on the major industrial manufacturer vendors, the Woodhead GATEway supports multi-messaging that enables it to communicate and interoperate.
The Woodhead GATEway embeds a powerful processor running a real-time OS kernel. Through its on-board Database (32 Kbits / 32 Kwords), the GATEway performs all communication tasks to exchange data between equipment by running automatic Read/Write cyclic functions and allows receiving unsolicited Read/Write requests. The Woodhead GATEway includes a software package running under Windows XP or 2000 environments able to setup the GATEway by using a remote TCP connection. The package includes a set of powerful tools to perform features such as: Ethernet and Serial protocols configuration Cyclic functions setup and monitoring Graphical Network Diagnostic tools for Ethernet Process data access utilities Upload/Download of GATEway data for extended Diagnostics
多协议网关支持2种或多种协议之间的通讯。
串口支持:
AS511masterSiemens S5
Modbus RTU/ASCIImasterSchneider Electric
Modbus RTU/ASCII slave Schneider Electric
SNP-XmasterGE Fanuc
TI-DirmasterSiemens/TI
Uni-Telway Slave, client/server Schneider Electric
DF1 Full/Half-Duplex Allen Bradley
Ethernet支持:
Alnet II TCP/IP client/server Altus
Modbus TCP client/server Schneider Electric
FINS TCP/IP client/server Omron
SRTP TCP/IP client/server GE Fanuc
SRTP TCP/IP client/server Alstom/Cegelec
Melsec A & Q TCP/IP client/server Mitsubishi
Uni-Te TCP/IP client/server Schneider Electric
Ethernet
Industrial Ethernet client/server
?? TCP/IP (S7, S5,TI)
Siemens
PCCC on Ethernet IP Rockwell Automation
Profibus:
Profibus (S5,S7,MPI, DP Master/Slave) Siemens + EN 50170
GE智能平台“Proficy 新产品、新应用”客户交流会成功举行
GE智能平台“Proficy 新产品、新应用”客户交流会研讨会
[典型应用]谁说小型污水厂不能实现智能运营管理
[典型应用]看GE智能平台如何帮助丹麦哥本哈根机场全面提升运营效率
[典型应用]GE智能平台助力康奈尔大学提升校园运营管理
